  Soarer Central * Transmission * Torque Converter Previous Previous    Next Next
Chrsitopher Butler
2.0 TT
Monday, April 17, 2006 - 04:24 pm, by:  Chrsitopher Butler (Amsracing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am looking at buying a 1988 Twin Turbo 2.0l Soarer the only problem is it's got a stuffed torque converter and I was wondering how much it would cost to get that fixed? Whether i should replace it with standard one or get a better one if so how much are they installed (roughly). Thanx for your help
Chris Davey
Corona
Tuesday, April 18, 2006 - 10:02 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
firstly, how do you know it is stuffed? You could get a replacement one pretty cheap on toymods I would imagine as most people don't want the autos. I sold my old box for $50. You can then get it rebuilt and the stall changed which turns it into an as new converter. I would recommend a slightly higher stall as the gz20 doesn't really get moving until 4000rpm.
Chrsitopher Butler
2.0 TT
Wednesday, April 19, 2006 - 11:18 am, by:  Chrsitopher Butler (Amsracing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The guy sellin it told me it was. I am getting it fully looked over at a mechanics. However it hardly moves at the moment and he is one of my good mates and knows his stuff. Yeah so would I be able to get away with rebuildin it and getting stall changed and getting it installed for under $800 or so?
Chris Davey
Corona
Wednesday, April 19, 2006 - 11:30 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got a 1jz converter modded, rebuilt, furnace blazed and stall changed for $360 at QLD torque converters. Should be able to get it done for a similar price somewhere down there.
Paul Bernasconi
wa
soarer tt
Wednesday, April 19, 2006 - 01:16 pm, by:  Paul Bernasconi (Pauli) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
chris, was that included in fitting?
keep in mind the whole gearbox has to come out to remove and fit it.
Chris Davey
Corona
Wednesday, April 19, 2006 - 01:53 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nope, no fitting. Probably $200 or so in labour for a mechanic with a hoist at $50/hr.
Chrsitopher Butler
2.0 TT
Wednesday, April 19, 2006 - 04:43 pm, by:  Chrsitopher Butler (Amsracing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
so just say $600 fitted and it's sweet? Would a normal mechanics be able to do the whole thing like change the stall and stuff? as well as fit it?
Chris Davey
Corona
Wednesday, April 19, 2006 - 05:55 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep.
Chrsitopher Butler
2.0 TT
Wednesday, April 19, 2006 - 10:03 pm, by:  Chrsitopher Butler (Amsracing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
too easy then thanx for your help, apart from toymods where else should i look at to buy a torque converter (a good one)?
