Friday, April 21, 2006 - 03:38 pm, by: Daniel Clarke(Dieseltrain)
TT Soarers have an ignition retard/fuel cut that kicks in upon gear changes. Its to help save the massive stresses that turbo's put on clutches inside the box on gear changes. So in effect it sounds like Snap Crackle Pop... But its there for a reason. When you say " Off the Line" do you mean as soon as the boost kicks in you get a slight miss for a second and then on gearchanges as well?
i meant, standing start, id put foot to the floor, it launches, gets up and bounces off the limiter. previously, in power mode it would not hit the limiter at all
ive got a boost controller, but its still running stock boost. had the spark plugs changed recently, i cant remember the model number but it was stated as bosch gtr or something, so decent quality.
Tuesday, April 25, 2006 - 02:16 pm, by: Luke Nieuwhof(Luke_nieuwhof)
It sounds odd it would hit the limiter. I don't normally hear the flutter on full throttle gear shifts but I don't hit the limiter either and I've done quite a few runs at the drags this year. Only time I hit the limiter is in the burnouts when shes spinning the tyres
