  Soarer Central * Transmission * OD wants to work today and not tomorrow any ideas Previous Previous    Next Next
Khalid Sarwari
T
Wednesday, May 03, 2006 - 07:03 pm, by:  Khalid Sarwari (1jzspeed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anyone got any idea whats happening with my transmission my OD wants to work some days and not others but i dont get any error messages, does anyone know what might be wrong, this with a fully rebuilt power pack trans from MV autos purchased a month ago. Any Ideas
Dave Hart
Waikato
UZZ32
Wednesday, May 03, 2006 - 07:33 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Take it back and tell them. Could be just a temperamental switch.
Khalid Sarwari
T
Wednesday, May 03, 2006 - 08:34 pm, by:  Khalid Sarwari (1jzspeed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ahh oks wel i am in melbourne and they are in sa
3.0 GT
Thursday, May 04, 2006 - 06:50 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sticking solonoid?
Mark Paddick
Thursday, May 04, 2006 - 10:11 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The solenoid would give error codes but an intermittent switch would not.
Khalid Sarwari
T
Thursday, May 04, 2006 - 01:58 pm, by:  Khalid Sarwari (1jzspeed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hmmm and internitent switch ya say mark, so how would one figure out if its the switch or diagnose it.
Dave Hart
Waikato
UZZ32
Thursday, May 04, 2006 - 02:08 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Khalid, start at the button on your shaft.
(That should get a response from CD).
Mark Paddick
Thursday, May 04, 2006 - 06:03 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't even want to think about that one
Take the shifter lever off and stick a bit of bare wire in the contacts for the o/d switch.
Khalid Sarwari
T
Thursday, May 04, 2006 - 10:02 pm, by:  Khalid Sarwari (1jzspeed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
mark the switch there is all good cuz it comes on and off on the dash and i have checked the contact to make sure all is well and clean.
Any other ideas guys.
Thanks for the input much appreciated.
Blaine Hanson
Saturday, May 06, 2006 - 01:08 pm, by:  Blaine Hanson (Blaine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine does the same thing - some days it has a mind of it's own. Sometimes works, sometimes does not. I replaced the whole mechanism with the buttons on it and have new solenoids and it made no difference. Some days it even shifts by itself -makes for interesting driving... I will be swapping transmissions soon so I'll see if that helps - otherwise it must be switch / wiring / computer - related.
Robert Hayden
1991 UZZ32, 1991 UZZ32 Supercharged, UCF11 Celsior 1990
Saturday, May 06, 2006 - 01:29 pm, by:  Robert Hayden (The_boss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Little black speed sensor. Passengers side of box, up high and close to engine. Two 10mm head bolts and pull it out. No oil loss.
Should be a little black cylinder about 19mm diameter x 28mm long. Throw it over the right shoulder and source another one to replace it.
Common fault. Generally the OD light will come on but it won't shift into OD. Some times the light blinks.
Blaine Hanson
Saturday, May 06, 2006 - 01:49 pm, by:  Blaine Hanson (Blaine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Rob - I'll give that a try.
Angus Shen
SC400 TT
Reg: 08-2006
Friday, October 27, 2006 - 09:56 pm, by:  Angus Shen (Loveflies) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob, will this coz losing power? coz my one always losing power after i kick the oil, but the engine goes ok, checked with the computer, and shows the message "NO.2 XXXX solonoid"(forget what the message said~"~) any idea?
Braden Murdoch
Cressida 1JZ TT
Thursday, November 23, 2006 - 07:56 am, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My mate's 1JZ won't shift into OD at all, swapped ECUs with mine for testing purposes, and turns out that his ECU was crook. Might pay to check yours, esp for leaking capacitors.
Mark Paddick
Thursday, November 23, 2006 - 04:42 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got spare standard 1J computers.
Harry Lemmens
Thursday, November 23, 2006 - 05:54 pm, by:  Harry Lemmens (Wombat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Idea ... Sounds like the transmission solenoid is cactus!
Not all that uncommon.
