Wednesday, May 10, 2006 - 06:48 pm, by: Sean Camelin(Krener)
Can someone tell me what the part number is for this item please. It's the drive gear for the speedo sensor. This is the culprit for my speedo not functioning. I also discovered that I can only spin my fingers at 17 kph. Any help would be appreciated. Thanks Sean
Neil Griffiths Trader NSW I have MORE Soarers than Hayden :-)
Friday, May 12, 2006 - 01:06 pm, by: Sean Camelin(Krener)
Yep, that's the one. Rear left of the gearbox on the extension housing. Sits just above the gearbox mount. 12mm socket to remove the bolt that holds it in. In the kit I got from Mr T was the gear assembly and the 'O' ring seal.
I was actually wondering why it's made from plastic. It would make sense to get something machined from metal as a more permanent solution, unless it's a common issue and a metal speedo drive gear would damage the gear inside the gearbox that drives it.
Sunday, April 29, 2007 - 06:30 pm, by: Sean Camelin(Krener)
Apologies for dragging up an old thread but this little bugger has failed AGAIN.
I'm wondering how many times those of you who have had their car for a few years have had to replace this cog, cause it seems a tad odd that the teeth strip off inside 12 months.
Neil Griffiths Trader NSW I have a Cadillac and a Supercharged Manual V8
Sunday, December 20, 2009 - 12:26 pm, by: Stuart Morgan(Stumagoo)
I have the same prob with my UZZ31, would I be right in assuming I go to Toyota and ask for part 33482-59025? or do I include the prod date (94019709) as well? Ill have to order it over the phone, and would prefer to sound like I know what Im talking about....
Sunday, December 20, 2009 - 04:33 pm, by: Stuart Morgan(Stumagoo)
Is there a trick to getting these back in?.... I just tried to put mine back in after inspecting the nylon gear (stripped) and had trouble getting it to go all the way back in flush!... Now I have broken the cast mount. Spewin!... Ill have to try get another sensor unit!!! Also im presuming I cant drive it until the sensor is back in or Ill loose my trans oil..... Is that right?
Monday, January 11, 2010 - 09:43 am, by: Brian Rignall(Cashmere)
Complete instructions for removal / replacement are attached.
I bought mine recently from Castle Hill Toyota. They will take your order over the phone and post the parts. Part Number: T33482-59025 Description Gear, Speedo JZA80
