Saturday, May 20, 2006 - 06:59 pm, by: Syed Shah(Syed_shah)
I have looked further, suffice to say it is not easy. I am planning to build my soarer 'box instead, and if that breaks I will keep everyone updated on what I then go to.
Wednesday, May 24, 2006 - 09:56 pm, by: Blake Gloyn(Blakenz)
from memory three of the 5 plugs are different,there is no kick down cable on the supra jza80 box,and the output shaft to driveshaft is completely different too.
Sunday, September 03, 2006 - 08:11 pm, by: Blake Gloyn(Blakenz)
the torque convertors are differing depths,the holes on the torque convertors are slightly different spacing,and the splined shafts that go into the convertor are different lengths,which could pose a problem to the oil pump in the trans. the supra(all 2JZgte) box requires a factory ECU to change line pressure when shifting, with out it, the trans will burn out.it's a sad state of affairs,... had to change my plans.
