Friday, June 02, 2006 - 12:39 pm, by: Yang Luo(Steven)
i just changed my gearbox oil this morning. then i took the car for a normal drive. it doesn't make any differeces.also i asked them to check the gearbox number.they checked the bottom and both side of the gearbox(except the top), they can't find the number. anyone can tell me where is it? is there any other gearboxes can put in 93 TT soarer
Saturday, June 03, 2006 - 11:07 pm, by: Yang Luo(Steven)
when i put in 1st gear is hard.like something block up.. do you know where i cant find out the gearbox number from my gearbox.because i think my TT is convertion
Monday, June 05, 2006 - 03:04 pm, by: Jack Chiu(Wilbyz)
Yang Luo wrote on Saturday, June 03, 2006 - 11:07 pm:
It's usually impossible to get into 1st gear if I'm going anything faster than 10km/h ...
I have to say the R154 gearbox is a clunky box indeed, but I like it that way, lets you know you've actually done something besides just having a stick in your hand! ...
Am using Redline Lightweight Shockproof oil.
Yang Luo Tinkerer vic soarer 6cyl twin turbo manual
Wednesday, June 07, 2006 - 01:55 pm, by: Jack Chiu(Wilbyz)
Give it about a month and it'll become easier.
I've had my Clutch and Flywheel replaced recently too (Excedy Organic and JUN light flywheel). It was very very tacky getting into First gear, but has since eased up.
Wednesday, June 07, 2006 - 02:01 pm, by: Marius Hainal(Torque)
In that case , I would do 2 more things : -check and see if the clutch is adjusted properly ; the clutch should disengage about mid-way through pushing the pedal to the firewall , or somewhere higher up . -check clutch fluid , make sure it is clean . to be sure , flush with new one.
These cars have a harder shift then most of manual vehicles ; my wife also says she finds it hard to change gears ( she is small and tiny , and she also drives a manual , we both hate automatics with a passion ) .
You also need to go to a full stop before engaging 1st gear , that is not a fault , but rather a restriciton due to design on manual gearboxes...
I found Redline MLC to be good for my gearbox , it has improved shifts when cold
Other than this , nothing helps but getting used to it.
