  Soarer Central * Transmission * How Do You Change Oil In Manual gearbox? Previous Previous    Next Next
Louis Angelopoulos
Soarer V8 Lmt
Saturday, July 15, 2006 - 10:57 pm, by:  Louis Angelopoulos (Revolution) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys I did a search, and had a look in the Maintenance section, but theres no description for changing the oil in a manual trany.
Can some one please provide some insight?
Thanks in advance everyone!!
Duy Le
GT-T Manual
Saturday, July 15, 2006 - 11:04 pm, by:  Duy Le (Sor44h) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Drop the oil out from the gear box sump.
On the Passengers side on the side of the gear box, theres another plug, fill up the oil through there. I saw Niall do this to mine the other day, but I could be wrong
Btw, I used Redline Light weight Shock proof thanks to Shane for showing me the light to it. I swear by it!!!
Ben Lipman
Sunday, July 16, 2006 - 06:56 am, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just remember the golden rule: check you can get the filler plug out before you try the drain(sump) plug. Once you drain the oil and you find the filler plug seized there is no way of getting your lovely new oil in. Older oil is so much better than no oil at all. Learnt that the hard way in an old car I once had.
Shane McInnes
JZZ30 GT-TL Manual
Sunday, July 16, 2006 - 09:01 am, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Duy,
So its all good now? you have 4th gear back?
BTW Duy, Your right BP Ultimate does last longer than Optimax.
Duy Le
GT-T Manual
Sunday, July 16, 2006 - 11:23 am, by:  Duy Le (Sor44h) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You wouldnt believe what happened Shane. The d1ck flop that did my clutch unbolted the shifter to the box to move to box back to change the clutch.
4th gear is a long story. Ill explain to you when I see you but lets just say it was negligence from the d1ck flop who did my clutch!!!
Duy Le
GT-T Manual
Sunday, July 16, 2006 - 11:24 am, by:  Duy Le (Sor44h) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shane McInnes wrote on Sunday, July 16, 2006 - 09:01 am:
Im always right!!!
Shane McInnes
JZZ30 GT-TL Manual
Monday, July 17, 2006 - 04:37 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Buggar.
If your always right, Whats this weeks lotto Numbers ;)
Catch Up with you soon anyway.
