  Soarer Central * Transmission * Open diff > LSD centre Previous Previous    Next Next
Phil Gibson
'94 black/black UZZ31
Tuesday, August 22, 2006 - 07:19 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Question - Who has fitted a Torsen LSD centre into their open diff housing?
Did the existing drive shafts fit?
I have been told (and the EPC backs this up) that all Torsen diffs have driveshafts with different splines so therefore you cannot use shafts from an open diff
Any thoughts? The driveshafts from torsen diffs have the part number 41309-24030 whereas the open diff ones have the part number 41309-24020 so they must be different in some way...
Gianni Matrogiannis
SC400 V8
Wednesday, August 23, 2006 - 04:31 pm, by:  Gianni Matrogiannis (Gianni) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They are the same
