  Soarer Central * Air Conditioning and Climate Control * Air Conditioner Filters Previous Previous    Next Next
Damien Murray
kildare
Reg: 10-2006
Monday, February 12, 2007 - 04:13 am, by:  Damien Murray (Stealth) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
read peters post on cleaning them and went out to do the same on mine.but i only got 1 filter out ?
thought there was two.i even stuck my fingers in to see if i could feel another one but i could not
any help ?
put the old one back in and it cant push up anymore so did some soarers only come with 1 filter
Monday, February 12, 2007 - 06:22 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, there should be two, one pulls out from the side after you have the first one out from memory (or is it the top?)
Monday, February 12, 2007 - 11:22 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damien there are 2. One is shoved right down the back of that slot. Look for a little tab to jiggle it out.
V8 Ltd manual
Monday, February 12, 2007 - 12:12 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
"Back of the slot" means toward the front of the car, not up.
Damien Murray
kildare
Reg: 10-2006
Monday, February 12, 2007 - 10:06 pm, by:  Damien Murray (Stealth) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks guys found it last night and got it out.
how dumb was i
Active V8 and a Factory Manual XF.
Thursday, February 15, 2007 - 07:46 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very. :-)
Mark Ribbans
UZZ-031 V8, 1972 Mazda RX2 Coupe, TE Gemmy
Friday, February 16, 2007 - 10:19 am, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damien, i did mine on Tuesday pulled one out, fully cleaned it and was ready to put it back in before i realised there were actually two. - So we're both dumb!
How dirty do they get! Mine were black as, cleaned them with spray on sugar soap.
Clayton Webb
'31 V8
Friday, February 16, 2007 - 04:41 pm, by:  Clayton Webb (Clackers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That Mr.Orange tough stuff that you use to clean the interior works a treat as well.
Karyn Cornwill
tt
Reg: 08-2007
Wednesday, September 19, 2007 - 08:10 am, by:  Karyn Cornwill (Limesoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can buy new air con filters from Toyota,think about 45.00 each. Tried cleaning them but they still smelled so i replaced them
Mustafa Akgul
Big Mac
Wednesday, September 19, 2007 - 09:38 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am getting some of these filters soon..and will be new.
Christian Zimmer
Reg: 09-2006
Wednesday, November 07, 2007 - 04:34 pm, by:  Christian Zimmer (Zimmi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Let me know how much they cost Muz
I went to clean mine when I got my car...and they were missing lol.
Also the white 'cap' that closes/holds them in is missing....need to find one from a wrecker. It appears that those little white pieces are different depending on what soarer you have. Found a couple that were different size.
Ashley Leach
GT Limited UZZ31 V8
Thursday, November 08, 2007 - 10:53 am, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And I just ordered new ones! :-(
Drew Rechner
Reg: 10-2007
Thursday, November 08, 2007 - 01:44 pm, by:  Drew Rechner (Drew1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I took mine out and gave them a clean, works a treat now.
They were in pretty horrible shape when i pulled them out though
