| Author |
Brett Moloney
TryHard Queensland UZZ31
Posts: 438 Reg: 07-2005
| As per heading. I have done a search with no luck. Are the EMV and Non EMV cars equipped with a different air con computer?. This is the one under the dash to the left of the steering column. |
Tim Pike
TryHard Queensland V8 GT-L UZZ31
Posts: 146 Reg: 08-2005
| Hopefully someone else can tell you for certain, but looking at the wiring diagrams, EMV and Non-EMV air con computers are different. This is because the EMV Air-Con computer is wired into the vehicle LAN which only the EMV type cars have (ie. thats how you control the aircon from the touch screen). Also it looks like the plugs might be different too. I can't say for certain though since I'm only looking at the wiring diagrams and have never actually seen both a EMV and Non-EMV aircon computer. But I'd be pretty certain that they would not be compatible due to the unit begin connected to the EMV via the vehicle LAN which only the EMV cars have. |
Brett Moloney
Posts: 439 Reg: 07-2005
| Thanks Tim, I've also been looking at the diagrams and although the plugs seem different they are basically all the same colours and seem to be going to the same controls. I was hoping someone may have a part number of each. |
Damian Ware
TryHard Victoria UZZ32
Posts: 491 Reg: 10-2005
| Brett, I have a spare EMV air con computer I will get you the part number off it today. |
Brett Moloney
Posts: 440 Reg: 07-2005
| What I cannot find in the wiring diagrams are the fan speed controls, the off control, the mode controls - basically all the controls on the non emv cars that control air con and climate controls. |
Posts: 5897 Reg: 05-2005
| I've been through the EPC Brett, but don't have anything conclusive to tell you. Once Damian puts up his part number I'll have a more thorough search in the catalogue for you  |
Damian Ware
Posts: 493 Reg: 10-2005
| Sorry mate my mistake I no longer have one. If I come across another one soon, I will let you know. |
Brett Moloney
Posts: 441 Reg: 07-2005
| Don part number is 88650 but I think this is the non emv so I need to know if the emv has the same air con computer (to the left of steering wheel near console) |
Posts: 5899 Reg: 05-2005
| Sorry Brett, but I'd need the full number, as in all 10 digits. And I can't see anything that LOOKS right in the EPC.
Darryn Dewar
DieHard Gisborne UZZ30 Soarer
Posts: 697 Reg: 09-2005
| It's listed as a AMPLIFIER ASSY, COOLER STABILIZER Don. If it's the part I'm thinking of |
Posts: 5900 Reg: 05-2005
| Yeah, I saw that Darryn. Wasn't sure if that's what Brett's looking for, but I'll check it out  |
Posts: 5901 Reg: 05-2005
| Ok, IF that's the part, then it's NOT EMV specific, but IS year specific. Also Brett, the number you gave matches up with the first part of the complete part number
Trader NSW 212Kw @ 8psi MANUAL Super Charged UZZ31
Posts: 3691 Reg: 07-2005
| Yes they are different.. EMV is next to drivers left foot rest, Whitey/Yelloish coloured box behind the Mirror ECU Non EMV is in the AC headunit ( Like the headunit you just purchased Brett ) |
Posts: 5902 Reg: 05-2005
| Buggar! |
Brett Moloney
Posts: 442 Reg: 07-2005
| You are all champions. Thanks for the responses gentlemen (I use that term extremely loosely ). That certainly clears up a bit Neil. I was going over all the different wiring diagrams for emv and non emv and it just didn't gel. |
Brett Moloney
Posts: 444 Reg: 07-2005
| Hey Neil this will be another useless box I can throw out to lighten the weight. Already got the emv, stacker,amplifier, navigation, radio tuner, tv tuner removed. |
Brett Moloney
Posts: 450 Reg: 07-2005
| Finally after over 140 soldering joints and approximately 8 hours labour from this
 to this
Paul Drane
TryHard QLD V8 Limited
Posts: 406 Reg: 07-2005
| Looking good Brett
Posts: 3709 Reg: 07-2005
| Excellant, Your next quest should be to remove the Traction Control  |
Brett Moloney
Posts: 452 Reg: 07-2005
| Remove the traction control! Very easy to do when it wasn't on the car to start with. (My favourite smiley!) I think I'm turning my 31 into a 30. |
Posts: 3717 Reg: 07-2005
| Well why ya still have the Trac button in the shifter panel ! |
Brett Moloney
Posts: 456 Reg: 07-2005
| Nah. It is an aftermarket switch used for OD. Never had traction control at all. Wanted it to look like it belonged there. |
Posts: 3723 Reg: 07-2005
| WOW,,with my eyesite and that pic it looks factory mate..HAHAHAHHAHAHAHHAHA |
