  Soarer Central * Air Conditioning and Climate Control * Air Con problems after replacing LCD head unit Previous Previous    Next Next
Peter Bowlay
Reg: 05-2007
Wednesday, May 02, 2007 - 08:52 pm, by:  Peter Bowlay (Pedro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was wondering if someone may be able to shed some light on my problem relating to air con.('91 V8).
I have the LCD screen going black so I got one from a wrecker and put it in, same problem, another one same problem. Went through air con check but still not cooling. Replaced LCD unit with my original unit. All buttons operate OK and after diagnostics, all clear (00).
Double check on connections behind head unit and all appears OK. Had gas check done and all OK. No cold air coming from unit. Any ideas what may have happened when I changed over the AC LCD head unit? The AC was working fine before I changed the head unit. Very frustrating!!! All fuses checked, kick panel and inside. Anyone had this problem or have I inadvertently broken wire in connectors?
Any help or advice appreciated.
Peter
Victoria (The Nazi State)
Active V8 and a Factory Manual XF.
Wednesday, May 02, 2007 - 09:48 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Possibly broken some connectors, does all other functions work (like face, foot, screen direction) etc etc. Check to see if the compressor clutch is engaging.
Peter Bowlay
Reg: 05-2007
Thursday, May 03, 2007 - 12:33 pm, by:  Peter Bowlay (Pedro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Dan,
Have the car in at the Auto elect today and he tells me all connectors Ok. Yes the functions all work and the says the compressor clutch is engaging.
Really weird ????
Peter
Peter Bowlay
Reg: 05-2007
Thursday, May 03, 2007 - 06:53 pm, by:  Peter Bowlay (Pedro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Apparently wrong connection behind head unit.
Same size plug put into wrong hole. (heard that before somewhere)
Anyway, air con now up and running, however, TEMS lamp does not come on now???. Not the bulb, coz it's shows when ign first turned on. and rocker switch is OK.
Oh well, sometimes one feels like a real goose.
Thanks for the suggestions and help guys.
Thursday, May 03, 2007 - 07:57 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And I dropped 2 new LCD screens today and broke them..
mongrel.
Lew Radbourn
jzs147 92 / 95 jzz31 98' / jzz30 ute92' / uzz30 93'/ 2 X uzz31 92' s
Thursday, May 03, 2007 - 08:13 pm, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mate thats OK
just charge Mark extra for fitting the VVti.
HAHAHAHAHAHHAAH
