  Soarer Central * Air Conditioning and Climate Control * Air Con Light but no cigar Previous Previous    Next Next
Leo Croker
Meath
Reg: 12-2006
Friday, June 08, 2007 - 09:48 pm, by:  Leo Croker (Leonardomonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My air con is not working at all, push button light comes on and nothing, engine idle does not change at all.Does this mean i need a re gassing or is it stuffed, the rad was replaced before i bought the car so i dont know if that is a factor. Its starting to get hot over here and i would really appreciate any help
JunkFilterer
Friday, June 08, 2007 - 10:16 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It sounds like the gas has leaked out, but have someone find and fix the leak or regassing is only a temporary fix. One common leak, is an O-ring at the front. Shine a torch in through the front grille and if things look a bit oily on the passengers side, it is the O-ring leaking. It is a simple and easy (low cost) fix.
Leo Croker
Meath
Reg: 12-2006
Friday, June 08, 2007 - 11:23 pm, by:  Leo Croker (Leonardomonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks i will give it a go, low on funds so fingers crossed
Danny Minns
Reg: 10-2007
Thursday, October 11, 2007 - 05:28 pm, by:  Danny Minns (Poju89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it could be out of gas but you'll need someone with all the gear to check it first, well thats the law but you could just look around all the pipes and compressor(should be called a pump cause nothing gets compressed) for oil and even the condenser some times you might find something. Just keep in mind that the people that do air cons should always check it over for all the leaks before they can re-gas, its a law.
air con quotes can get a bit steep, tho will normally have a warranty to that shop if it doesn't work.
oh! just remembered if you can see any stickers in the engine bay about uv dye then wait till night and get a black light.
just keep in mind that you'll have to see an auto electrician or air con place to fix it and re-gas, and they'll check it all over anyway(or should) by law.
Dave Billings
Louisiana
SC 300, Manual Transmission
Reg: 06-2007
Friday, October 12, 2007 - 06:48 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Even if you have no freon (gas) in the system, the compresser should still come on pulling a draw on the engine.
Leo Croker wrote on Friday, June 08, 2007 - 09:48 pm:
You may need more than regassing.
Dave Billings
Louisiana
Reg: 06-2007
Friday, October 12, 2007 - 06:49 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does it blink like its recycling? (the aircon light)
JunkFilterer
Friday, October 12, 2007 - 12:54 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If the gas pressure drops, the compressor won't switch on. Toyota smarts. :-)
Danny Minns
Reg: 10-2007
Friday, October 12, 2007 - 04:22 pm, by:  Danny Minns (Poju89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
as peter said compressor wont turn on without any head pressure.
and its never just needs to be regassed, it'll have a leak. take it to an aircon place and get a quote which wont cost much, then deppening on what it'll cost to fix is your choice to pay or not really.
Dave Billings
Louisiana
Reg: 06-2007
Friday, October 12, 2007 - 11:49 pm, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Friday, October 12, 2007 - 12:54 pm:
Really?? I had a slow leak about 3 years ago, and when I turned on the a/c it blew hot air, but the compressor still kicked in putting a drain on the engine. I had to eventually replace the whole system for $1600 USD!!
JunkFilterer
Saturday, October 13, 2007 - 12:38 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is a pressure sensor that should have stopped it, saves damage - unless they left it off the SC-300?
Dave Billings
Louisiana
Reg: 06-2007
Saturday, October 13, 2007 - 01:11 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Saturday, October 13, 2007 - 12:38 am:
Or mine was broken, maybe thats why they recommended replacing the whole unit.
Karyn Cornwill
tt
Reg: 08-2007
Saturday, October 13, 2007 - 06:57 pm, by:  Karyn Cornwill (Limesoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Same Dave.I had to replace the whole system in mine, Cost a small fortune but worth it in the long run,
Dave Billings
Louisiana
Reg: 06-2007
Saturday, October 13, 2007 - 11:30 pm, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, I'm in love with my minnie winterland!! LOL
