  Soarer Central * Air Conditioning and Climate Control * Installing the Condenser Previous Previous    Next Next
Lexus Roller Coaster
Friday, November 09, 2007 - 10:47 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Last night i successfully installed my spare condenser but encountered a problem. There are two 2 inch long bolts that join the alum plumbing pipes to the condenser wall. One of the bolts went back in ok but the other seemed to have no thread on the Condenser side. So the top bolt goes all the way in but it isnt doing anything.
Is there a way i can make this work ?
Monday, November 12, 2007 - 03:38 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Problem solved.
The little lock nut in the condenser was missing.
