  Soarer Central * Air Conditioning and Climate Control * Air Con Specialist Previous Previous    Next Next
Dennis Tito
TT manual
Monday, October 24, 2005 - 09:18 am, by:  Dennis Tito (Dennis) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, any recommendations for an air con specialist in Melbourne that has worked on Soarers before?
Also does anyone have a diagram of the A/c unit for the soarer, i can only find diagnosis sheets.
Mark Tierney
T/T
Monday, October 24, 2005 - 10:15 am, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im looking for an air con specialist in Sydney. I think my compressor is on the way out...noisy on start, whines a bit at idle.
Anyone have an idea of what dollars im up for if I need a new compressor?
Any recommendations for someone to take a look?
Mark
Christian Garcia
GTTTTTTTTL TTL GTLTLTLLL
Monday, October 24, 2005 - 10:39 am, by:  Christian Garcia (Garcia) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i too would like this info, as my air con doesn't work, and the summer feels like she is gonna burn.
Monday, October 24, 2005 - 02:01 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had my air-con regassed last year at B&N Automotive Air conditioning and they still have R12 gas available too
Their details:
70 Railway Rd
Blackburn
ph: 9878 2918
Jeff Wilkins
JZZ30 GT-TL
Monday, October 24, 2005 - 04:28 pm, by:  Jeff Wilkins (Calin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Re: R12 gas
Ya dont have to bother hunting high and low for the old gas any more.
Obviously you cant use the newer R134a(hope thats the right code) without changing your AC components either.
There is a new gas available that is compatible with the old AC system hardware and is (so they say) 20% more effective that the old R12 which was more effective that the R134a.
Dont know if thats true or not, however I have had it put in my car and the AC is bloody cold! Thats the main thing. Was ~$100 all up including die.
Clayton Webb
'31 V8
Monday, October 24, 2005 - 04:42 pm, by:  Clayton Webb (Clackers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I put HR-12 in mine. No modifications necessary. Cost $60
Dennis Tito
TT manual
Monday, October 24, 2005 - 08:44 pm, by:  Dennis Tito (Dennis) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
daniel do you if these guys do repairs as well?..cos mine involves some repair work not just a re-gas.. thanks for the info anyway..i'll give them a buzz
Mustafa Akgul
JZZ30-GTTL
Monday, October 24, 2005 - 10:40 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
a mobile air con repairer by the name of Elliot was reccomended in the alsc forum for sydney i dont have his number unfortunately..
Anish Varsani
V8 UZZ30
Tuesday, October 25, 2005 - 05:53 am, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
All soarers should have had their R12 AC's converted to R134 when they arrived in Australia. From what I've read, the AC is degassed and reciever dryer is removed before the cars are shipped.
So if you get it regassed, you should just be able to get it filled with R134.
If you want to use the new R12 (HR12) I was told that the system would have to be converted back to R12. I'm not sure what the difference is.
Cliff Newton
W.A.
Tuesday, October 25, 2005 - 11:05 am, by:  Cliff Newton (Tiger_x) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought a new compressor from toyota. Was about $600 from memory. It was cheaper than getting my old compressor re-conditioned. They recharged the system using HR12 ( or FR12 - not sure which one it was now, i will have to check ), with no modifications needed to be done.
Mustafa Akgul
JZZ30-GTTL
Thursday, November 03, 2005 - 11:36 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys i found elliots number give him a call if your in sydney as i will tomorrow..:-) was in the alsc archives..oh and thx to Blake.
"yeh its called all car air conditioning. his name is elliot you can get him on 0418 164 234 "
Mustafa Akgul
JZZ30-GTTL
Thursday, November 03, 2005 - 11:38 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
here is the full post from alsc..
Blake Roeleven
ALSC Addict
Username: Boostntt
Post Number: 248
Posted on Thursday, February 05, 2004 - 12:43 pm:
hey guys,
just dropping a note to any soarer guys without a/c in sydney.. Ive had 3 quotes for a regas over the last week, all about 290-380 for retrofit r134a for a 92 tt.. i rung this guy elliot from "all car air" he has done it for$165.. now im not an expert on this topic but from watching my bros regas on his r33 the day before, this guy was a lot more thorough..he has changed about 10 o-rings in my system vacuumed the gas out for like an hr put blankets all over my car e.t.c e.t.c new reciever drier/filter complete uv dye leak test (took about 30 mins) the result was air coming out at about 5.5 degress celcius..
overall i was very happy with the service and quality of the work, my air is working like new now and he did it at my home.. he does mobile jobs in sydney so if your in sydney definetly consider this guy when it comes to a/c repairs/servicing .. his number is 0418164234 (elliot)
if anyones got any questions feel free to ask me
cheers!
Shane McInnes
Friday, November 04, 2005 - 05:07 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah elliot is a good bloke and is his prices are very cheap, he fixed my air con up last yr for $150 which included.
Dryer,oil,dye,gas,O rings and 2 connections for the r134a gas.
Alan Chow
Saturday, November 05, 2005 - 03:40 pm, by:  Alan Chow (Kfchow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hrmmm my condensers leaking... anyone know how much it'll cost to replace?
JunkFilterer
Monday, December 12, 2005 - 01:09 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff, where did you get yours done? My A/C started to not work properly yesterday and it's bubbling like mad in the little glass viewer :-(
Bernie Juckers
Monday, December 12, 2005 - 10:23 am, by:  Bernie Juckers (Burn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pater, if it is any help, I can recommend AMA or Affordable Mobile Air-Conditioning. These guys are very helpful, charge reasonably and even better come to you. Contact Les on 0411667983 sthn area or Peter on 0402005412 nthn area.
Jeff Wilkins
JZZ30 GT-TL
Monday, December 12, 2005 - 04:36 pm, by:  Jeff Wilkins (Calin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter, I got mine done at Profix of all places (Elizabeth). Was recommended by a fella I know. Quite happy with the job they did. I went back early and the car was covered up with more cloth than a new born baby. They also had a hoist set up for low cars which is handy, my front bar disagrees with most hoists.
Clayton Webb
'31 V8
Monday, December 12, 2005 - 05:15 pm, by:  Clayton Webb (Clackers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Give Steve's Auto Electrical a call. Very, very well priced and he's mobile too. Uses HR-12 gas as well.
Tuesday, December 13, 2005 - 12:10 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone have any recommendations for Perth based ones? =P
JunkFilterer
Friday, December 16, 2005 - 03:27 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bernie, I went with your recommendation, very happy (so far) :-)
http://soarercentral.com/sc-forum/messages/31680/33107.html?1134708969
Ian Nunn
UZ30 V8
Reg: 12-2005
Thursday, January 05, 2006 - 12:52 pm, by:  Ian Nunn (Inunn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is there anyone in Sydney that can repair the climate control air conditioning on a SC400GT?
Jan Christiansson
Soarer V8
Thursday, January 05, 2006 - 03:34 pm, by:  Jan Christiansson (Janoc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can try 'A' CLASS AUTOMOTIVES (Bob Adamson)Unit D3, 2A Victoria Avenue, Castle Hill. Phone 96345024 or Mob. 0418325889 email
bobatwork@optusnet.com.au
He have done some work on mine.
Friday, January 06, 2006 - 05:20 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Still no recommendations for Perth people? ='(
Cliff Newton
W.A.
Friday, January 06, 2006 - 05:58 pm, by:  Cliff Newton (Tiger_x) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah come on Perth peeps! I need to get mine checked.. I had a brand new compressor fitted and HR12 re-gas about 12 months ago. When I first picked it up I didnt think it was as cold as it could be. Its fine if you have the fan on low and temp cranked at max cold. But as soon as you crank up the fan anywhere past 2 bars then it battles to keep up. Same goes when the car has been left out in the sun, it just takes ages to get cold. Im thinking maybe there is a leak somewhere. But we need someone we can trust in Perth to take a look at our Soarer Aircon needs! When taking fin temps, do you measure the temp at the fin when the fan is on high, low or medium?
Cheers!
Friday, January 06, 2006 - 06:31 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Look up the one to which Chelsie went, exclude it and pick another at random
Michael Bagshaw
Friday, March 31, 2006 - 05:12 pm, by:  Michael Bagshaw (Bajor1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was doing an oil change on my car earlier this week and was dismayed to see one of the low pressure aircon pipes covered in green dyed oil and a very slow bubbling coming from the fitting.
Thanks to this thread I was able to take the car to B&N Automotive Air conditioning (70 Railway Rd Blackburn ph: 9878 2918) and they fixed the leak, checked the rest of the system and cleaned and regassed it with ER12 (same as HR12).
Very relieved! Nice guys, good service and used to dealing with Soarers.
