  Soarer Central * Air Conditioning and Climate Control * A/C Magnetic Clutch Previous Previous    Next Next
Ashley Leach
GT Limited UZZ31 V8
Thursday, March 13, 2008 - 09:59 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone had any experiences with A/C Pressure plate rubbing after a serpentine belt change? I swapped the serpentine belts over tonight and afterward the pressure plate seems to be slowly rotating and rubbing even though the A/C isn't on. She's making a right old noise and a slight burning smell.
http://www.lextreme.com/ac.html
From what I read you can shim the AC pressure plate out to 0.05-0.15mm. Does anyone know what I use, is it a small steel washer or something else? Has any one had this happen before?
Ashley Leach
GT Limited UZZ31 V8
Friday, March 14, 2008 - 01:12 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just spoke to an A/C place. Can't get in until Monday but he did mention that it much be a bearing... Now as far as I can tell there isn't any bearing attached to the front pulley.
The only thing I can see is the Stator... Is this thing like bearing? Can it seize?
Rich O'neil
90 Celsior
Reg: 05-2006
Friday, March 14, 2008 - 06:08 pm, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You need to STOP running the compressor !!
It's most probably the nose cone bearing in the front of the compressor , that's what it runs on , what can happen is that the bearing gets sloppy and allows the things to touch or the bearing could already have turned in the housing making a huge mess !!
If the bearing turns in the front housing then it's goodbye compressor and maybe even a total strip of the system to flush the evaporator .
Get the compressor out and get it looked at .
Ashley Leach
GT Limited UZZ31 V8
Friday, March 14, 2008 - 09:04 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Compressor is only 1 year old. I replaced it with a brand new one from toyota.
