  Soarer Central * Air Conditioning and Climate Control * EMV to Non EMV Climate Conversion - Complete Walkthrough Previous Previous    Next Next
Richard Ferrara
Reg: 03-2008
Rating:
Votes: 2 (Vote!)
Saturday, April 26, 2008 - 05:38 pm, by:  Richard Ferrara (426440) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Guys,
After going through all the info on this site (and everywhere else on the net) I could not find a good walkthrough for this conversion from start to finish. I have just completed it and have documented the process.... so here it is for all to enjoy! :-)
It is quite simple really, below is the parts list.
Tools:
1. Soldering Iron
2. Solder
3. Wire Cutters / Strippers
4. 10mm Spanner
5. Phillips Head Screwdriver
Parts:
1. Soarer TT Climate Control Module
2. Loom for Climate Control with 2cm before its cut (you will need to extend it about 30cm, so if you can get one with that much left on it all good, I had to extend it.)
3. Enough spare wire to extend all the cables 30cm
Procedure:
1.Disconnect your battery (dont want a short now do we).
2. Extend the loom on the Soarer TT Climate Control Unit by 30cm.
3.You will need to remove the EMV (out of scope for this document, plenty of info on how to do this elsewhere, use the search).
4.Once the EMV is out of the way SELL IT! Then you will need to remove the Climate Control ECU. The reason you are doing this is that the Soarer TT Climiate Control Module has the Climate Control ECU built-in. The EMV does not. It is located under the dash (brown\yellow box) next to the Mirror Control Unit.
5.With the Climate Control ECU out of the way you should have three Orange connectors dangling down. If you feel up to the top of this loom you will find it is secured by one of those spread clips. Either pop it out (if you can) or cut if off. This will give you enough slack to be able to solder in comfort. You will need to solder these connections to the Soarer TT Climate Control Loom. Details on how to do this is below.
EMV CONNECTIONS
There are three orange connectors. We will call them connector A, Connector B and Connector C.
Connector A is laid out like this:
1,2,3,4,5 CLIP 6,7,8,9,10
11,12,13,14,15,16,17,18,19,20,21,22,23
1 = Red
2 = Black \ Red
3 = Yellow
4 = Blue \ White
5 = Pink \ Black
6 = Blue
7 = Purple
8 = Green
9 = Green \ Red
10 = Red \ Blue
11 = White \ Black
12 = Blue \ Red
13 = White
14 = Yellow \ Black
15 = Pink \ Blue
16 = Not Used
17 = Not Used
18 = Not Used
19 = Black \ Yellow
20 = Not Used
21 = Green \ Black
22 = Not Used
23 = Blue \ Red
Connector B is laid out like this:
1,2,3,4,5,6 CLIP 7,8,9,10,11
12,13,14,15,16,17,18,19,20,21,22,23,24,25
1 = White \ Green
2 = Blue
3 = Green
4 = Green \ Red
5 = Grey
6 = Purple
7 = Black
8 = Blue \ Yellow
9 = Green \ Yellow
10 = Purple \ White
11 = Blue \ Black
12 = Light Green
13 = Blue
14 = Red
15 = Purple \ Red
16 = Green \ Orange
17 = Yellow
18 = Black \ Red
19 = Black \ Yellow
20 = Grey \ Green
21 = Red \ Blue
22 = Blue \ White
23 = Blue \ Black
24 = Red \ Black
25 = Blue \ Green
Connector C is laid out like this:
1,2,3 CLIP 4,5,6
7,8,9,10,11,12,13,14,15
1 = Brown \ White
2 = Yellow \ Blue
3 = Pink \ Black
4 = Blue \ Yellow
5 = Not Used
6 = Not Used
7 = Brown
8 = Light Green \ Red
9 = Yellow \ Green
10 = Green \ White
11 = Grey
12 = Pink
13 = Yellow \ Red
14 = Not Used
15 = Not Used
SOARER TT CLIMATE CONTROL CONNECTIONS
There are another three connectors (mine were white). We will call them Connector D, Connector E and Connector F.
Connector D is laid out like this:
1,2 CLIP 3,4
5,6,7,8,9,10,11
1 = Green \ Black
2 = Not Used
3 = Black \ Yellow
4 = Blue \ Red
5 = Not Used
6 = Not Used
7 = Yellow
8 = Black \ Red
9 = Blue \ White
10 = Not Used
11 = Not Used
Connector E is laid out like this:
1 =Black
2 =Blue \ Yellow
3 =Green \ Yellow
4 =Purple \ White
5 =Blue \ Black
6 =Pink \ Black
7 =Yellow \ Blue
8 =Pink
9 =Blue \ Yellow
10 =Light Green \ Red
11 =Yellow \ Green
12 =Purple \ Red
13 =Green \ Orange
14 =Yellow
15 =Black \ Red
16 =Black \ Yellow
17 =Pink \ Blue
18 =Brown \ White
19 =Not Used
20 =Brown
21 =Grey \ Green
22 =Green \ White
23 =Grey
24 =Pink
25 =Yellow \ Red
Connector F is laid out like this:
1,2,3 CLIP 4,5,6
1 = Red
2 = Purple
3 = Red \ Yellow
4 = Green
5 = Green \ Red
6 = Red \ Green
7 = White \ Black
8 = White
9 = Yellow \ Black
10 = Not Used
11 = Not Used
12 = Not Used
13 = Not Used
14 = Not Used
15 = Blue \ Red
Connect them together like this (Dont worry when you finish if there are some cables that dont get connected these are extra wires for the EMV and such, tape them up):
D1 -> A21
D2 -> Not Used
D3 -> A19
D4 -> A12
D5 -> Not Used
D6 -> Not Used
D7 -> A3
D8 -> A2
D9 -> A4
D10 -> Not Used
D11 -> Not Used
E1 -> B7
E2 -> B8
E3 -> B9
E4 -> B10
E5 -> B11
E6 -> A5
E7 -> C2
E8 -> C3
E9 -> C4
E10 -> C8
E11 -> C9
E12 -> B15
E13 -> B16
E14 -> B17
E15 -> B18
E16 -> B19
E17 -> A15
E18 -> C1
E19 -> Not Used
E20 -> C7
E21 -> B20
E22 -> C10
E23 -> C11
E24 -> C12
E25 -> C13
F1 -> A1
F2 -> A6
F3 -> A7
F4 -> A8
F5 -> A9
F6 -> A10
F7 -> A11
F8 -> A13
F9 -> A14
F10 -> Not Used
F11 -> Not Used
F12 -> Not Used
F13 -> Not Used
F14 -> Not Used
F15 -> A23
6. Once this has been completed tidy up your loom (tape it up so its all together) and feed the cabling up into the centre console.
7.Connect the connections to the Soarer TT Climate Control Module.
8.Mount the Soarer TT Climate Control Module.
9.Reconnect your battery.
10. Done!
Matt Petersen
NA
Reg: 01-2008
Saturday, April 26, 2008 - 05:42 pm, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice write up Richard.
Which year does this apply to? There are variances in the climate modules but the plugs stay the same.
I got a later model climate unit and put it into my 93 and I lost fan speed.
Matt.
Richard Ferrara
Reg: 03-2008
Saturday, April 26, 2008 - 05:46 pm, by:  Richard Ferrara (426440) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Matt,
I'm pretty sure this would be 91 - 96... Hell my climate control unit was from the united states and I didn't know what year model the car was ( buttons are backwards, its actually better because now the AC button isn't so far away :-) ). The pins were backwards too, but the colour codes were the same.
As far as your fan speed goes, Im sure if you look through the wiring diagrams you should be able to get that working.
Should probably put a disclaimer to do at your own risk as your dealing with electronic components. If your not competent give it to a pro :-)
Matt Petersen
NA
Reg: 01-2008
Saturday, April 26, 2008 - 05:53 pm, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I will have to dig out my info on this but I think there are three variations on the climate module, 91-93, 94-96, 97 on.
I might be slightly out on those dates but I am sure there were more than two variations.
You would have to wonder why they altered the pinout but left the connectors the same....
Matt.
Richard Ferrara
Reg: 03-2008
Saturday, April 26, 2008 - 05:56 pm, by:  Richard Ferrara (426440) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Feel free to add your info to this doco
EDIT:
Just checked the site I purchased it from, mine was out of a 1993 model but that it would fit 92 - 96
Joshua Olm
V8 GT LTD UZZ31
Reg: 05-2007
Wednesday, April 30, 2008 - 08:56 pm, by:  Joshua Olm (Iwannasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
lol ya could have put this up a few weeks earlier mate would have saved me working it all out myself
Good work mate.
Matt Petersen
NA
Reg: 01-2008
Thursday, May 01, 2008 - 04:19 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looking at the wiring for the 96 on it's quite different from the earlier models. There also appears to be some differences at the actual blower assembly which would indicate that none of the bits are completely interchangable.
Matt.
Daniel Renahan
GT-L Limited V8
Reg: 12-2007
Saturday, July 19, 2008 - 03:34 pm, by:  Daniel Renahan (Liasis35) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great tutorial!! i have a problem though with connecting E13-> B16 and E21-> B20 and E24-> C12 i dont seem to have any wires for those on the non emv plugs. I have installed everything into car and tt unit lights up but has nothing on the screen and beeps when pressing any of the buttons.
Simon Adams
Reg: 01-2007
Saturday, August 09, 2008 - 09:36 pm, by:  Simon Adams (Simmo152) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Daniel,
I was just wondering if you sorted out your climate control? The reason I ask is I'm about to attempt the same conversion and it would appear that my non emv connector E does not have pins 19 and 24 attached. I was thinking of perhaps inserting a crimp of some description or soldering a wire directly to the pin on the back of the TT unit where the connection does not exist.
Oh and thanks to Richard for the original tutorial.
Luke Gomer
Dorset
Uzz31 LTD
Saturday, August 09, 2008 - 11:54 pm, by:  Luke Gomer (Luke) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you look at the Jeff Harper wiring diagrams you will see that there is a wire for both speed pulse and telephone mute - neither of which I connected (the contacts were missing anyway )
Simon Adams
Reg: 01-2007
Sunday, August 10, 2008 - 08:27 pm, by:  Simon Adams (Simmo152) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Luke,
Thanks for the advice, unfortunatly I do not have access to the Jeff Harper wiring diagrams. I guess they're part of the "Soarer Bible" which has just about everything! I should buy a copy.
My concern is that Richard, Daniel and myself have connectors with different missing wires and the wiring loom I have sourced has come from a different Soarer than the climate control unit.
I notice that Non EMV plug E 19 according to Richard's tute is unused but I still have E 24 pink wire missing. Are these two the "speed pulse" and the "telephone mute"?
Thanks mate, I will post tutorial for anyone who wishes convert their EMV to a new DVD touch screen and Climate control unit.
Thanks
Simon
Luke Gomer
Dorset
Uzz31 LTD
Monday, August 11, 2008 - 01:02 am, by:  Luke Gomer (Luke) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Simon, you have access to the wiring diagrams if you buy them ;-)
Remember that NOT all cars have telephone - so the Tel Mute wire is of use and may or may not be available depending on whether the loom plug came from a car with telephone or not. The speed pulse wire was not connected on the conversion I did because again, the wire was not on the TT loom plugs.
So E19 and E24 were not required on the vehicle I did.
I will add however, the above tutorial seems to miss off the De-fogger (pin 18 connector I on JF diagrams - connector A above)for the rear screen and the button illuminations too as my wiring differs.
Its easy to do tutorials when others provide the answers ;-)
Jamie Metropoulos
wa
lexus v8 LEXPLAY
Monday, August 11, 2008 - 10:40 am, by:  Jamie Metropoulos (Lexdoit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
your the man. im about to do this as well and this is going to save a lot of headaches and time.
thanks again. good work.
Daniel Renahan
GT-L Limited V8
Reg: 12-2007
Thursday, October 16, 2008 - 01:55 pm, by:  Daniel Renahan (Liasis35) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys sorry bout the long delay in replying!! As it was such a hassle to be under the dash for so long i have just left it as is lol but having no aircon is starting to take it toll up here in Far North Queensland!! I have a feeling it may be the actual TT control may be faulty.. The screen lights up green and when the buttons are pressed they beep but nothing else happens.. I am moving to Melbs in two weeks were if anyone with knowledge of this conversion could help me out i would be greatly appreciated..
Richard Ferrara
Reg: 03-2008
Wednesday, November 19, 2008 - 05:40 pm, by:  Richard Ferrara (426440) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looks as though your unit is faulty mate. My AC works a treat :-)
