Friday, May 02, 2008 - 02:21 pm, by: Chris Papas(Papasc)
When I have the air on "in-cabin only" (reticulation), it seems I'm still getting the smells from outside while driving. The filter was changed recently.
Saturday, May 03, 2008 - 03:43 pm, by: Peter Nitschke(Pen)
The foam seals tend to break down and get blown out through the vents, so it might not be airtight.
Might be worth finding a clear road and just testing that the smell isn't there in either fresh or recirc modes, as it may be coming from elsewhere, eg crud on the A/C unit.
Sunday, May 04, 2008 - 10:15 am, by: Scott Casey(V8soarer_1991)
There is an air-con spray that you can buy. This spray kills all the bacteria spores that accumulates on an in your air-con system over time. Sometimes you can tell if you have an "greasy, oily, foggy" front windscreen, which are the bacteria growing!!!. What you do is go for a drive and get the air-con going on the coldest setting, while the air-con is still going spray the stuff in the intake of the air-con "vents where the wipers are". Use about half a can and should be right.
Wednesday, June 11, 2008 - 01:47 pm, by: David Vaughan(Davidv)
Behind the one you found. Take out that one, look behind it and pull the tab to bring it forward then down. This is a famous question often answered, in case you want to search for more complete explanations or pictures.
Wednesday, June 11, 2008 - 05:06 pm, by: Michael Keen(Spoilt)
Peter Nitschke wrote on Saturday, May 03, 2008 - 03:43 pm:
haha you will only find clean roads in the country ehehy not in the city,, hehe could not help my self
