Thursday, May 22, 2008 - 08:28 pm, by: Kyle Wathen(Cspot)
The other day i tried adjusting the fan speed with the heater on and it appears to be stuck on the lowest level.
When i press the fan speed button the indicator on the A/C display moves up and down but the flow rate of air coming from the vents doesn't change at all.
Anyone had this problem? or know the cause/solution?
Friday, August 15, 2008 - 04:26 am, by: Matt Petersen(Mattmannz)
Yep they are both in the fan assembly. Both have a set of wires running to them so you should be able to find them that way.
The transistor module is tucked way underneath at the back against the firewall. To get mine out I had to remove the false floor to allow me to get a small screw driver in there. Refitting is a PITA.
Monday, October 13, 2008 - 02:26 pm, by: Brett Harris(Stay_beautiful)
Thanks for the pics Kyle as I have the same problem but for the last fan setting and then it's flat out. Where did you get your replacement parts from to fix it and what did it cost you?
Monday, October 13, 2008 - 03:31 pm, by: Matt Petersen(Mattmannz)
If it goes on flat out then in theory it's the resistor module, the transistor module controls the high speed and the resistor the low speed.
When I was trouble shooting my high speed only fault I got second hand parts from a JZZ30 and swapped them in. You want to stay close to the same year as there was a wiring change in about 94 I think.
