| Author |
Neil Mystery
Tinkerer Ontario Soarer TT
Posts: 19 Reg: 06-2008
| Would anyone have any diagrams on the soarers heating system? My heater is not working at all and I would like to diagnose it, but I have no documentation on the soarer. Please point me to to any diagrams or manuals on the heater system Thank you, from a very cold person in Canada |
Posts: 9996 Reg: 11-2004
| Hi Neil, it's probably the VSV valve and can be bypassed. Located here.
Neil Mystery
Posts: 20 Reg: 06-2008
| is it the same for TT and V8? would bypassing mean the heat will be on at all times? thanks, Neil |
Posts: 9998 Reg: 11-2004
| Yes and yes. Bypassing actually involves just changing the little vacuum tubes that activate it, so it could be easily reversed until it's replaced. |
Posts: 9999 Reg: 11-2004
| Briefly, the temp control in the car activates the a servo allowing the vacuum to open the heater water valve. If the VSV motor dies, then nothing works. The bypass feeds the vacuum direct to the valve causing the hot water to flow all the time. |
Neil Mystery
Posts: 21 Reg: 06-2008
| ah i See, so I need to run a line from before the turbos to the VSV valve. |
Posts: 10004 Reg: 11-2004
| To bypass the VSV, you should be able to pull the hose coming from the manifold off the VSV end at the bottom, then hook it to the top of the diaphragm dome instead of the short hose there now.  |
Neil Mystery
Posts: 22 Reg: 06-2008
| Thanks Peter, I know exactly how to diagnose my issues now. I will keep you posted. |
Neil Mystery
Posts: 23 Reg: 06-2008
| I have bypassed the actuator so I know its either the VSV Valve of the electrical input to the VSV valve (the heat works). I wish there was a manual like the toyota supra repair manual for our cars. These things give a step by step procedure to diagnose and repair anything in the car. Anything like that available for the soarer? I want to know what voltages should be going to the switch or if the voltages are pulsed. Thanks, Neil |
Posts: 10013 Reg: 11-2004
| It should be the same as for the Supra. Look for 12v in the female plug on the harness side. You can also replace it with a Camry VSV fairly cheaply, but you need to cut/solder the plug from the old one to the new one. |
John Street
TryHard NSW Soarer TT
Posts: 157 Reg: 08-2005
| Peter, I have a TT with the same problem, what model Camry VSV fits Soarers? Cheers |
Posts: 10017 Reg: 11-2004
| Toyota part # 88690-32280. Though it may have changed as that is a couple of years old when it was around $70. |
Neil Mystery
Posts: 24 Reg: 06-2008
| what year/trim camry is that from? In canada these part numbers do not work..I have no idea why.. |
John Street
Posts: 158 Reg: 08-2005
| Thanks Peter, I'll try Mr T |
Posts: 10019 Reg: 11-2004
| Neil, this is where we may need the help of The Don. |
Posts: 10020 Reg: 11-2004
| Perhaps if I mention sheep it may get his attention?  |
Moderator New Zealand Mercedes Benz SLK230 Kompressor
Posts: 7083 Reg: 05-2005
| Hey ewe's fella's.........The only number I've got is the gen-u-wine Snoarer one, which is: 87240- 24030 and fits ALL JZZ30 & UZZ3# 1991 - 2000. I think the Camry one was a 93 - 95 4cyl model, but I'm not sure.
