  Soarer Central * Air Conditioning and Climate Control * Aircon regased... 2 days later ... no more aircon Previous Previous    Next Next
Blake Davies
S A
Factory 5sp TT
Monday, October 13, 2008 - 11:49 am, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello
I just got my aircon regased. (I had a pressure test done before it go regased.)
It work fine from the day it was done (It was ICE cold). than i park my soarer in my shed for a day. To fix my door trims. And the next day i had to drive somewhere. guess what the aircon isn't working. I cant feel any cold air at all.
Matt Petersen
NA
Reg: 01-2008
Monday, October 13, 2008 - 01:17 pm, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can you see if the compressor clutch is kicking in?
There are a number of inputs to the climate ECU that will stop the clutch from engaging.
Matt.
Ryan Rankovic
Soarer TT GT-TL
Monday, October 13, 2008 - 02:35 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have you taken it back to the place that regassed your aircon?
Blake Davies
S A
Factory 5sp TT
Monday, October 13, 2008 - 05:12 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matt Petersen wrote on Monday, October 13, 2008 - 01:17 pm:
Matt.
I'm not sure yet... how do you tell?
Drew Rechner
Reg: 10-2007
Monday, October 13, 2008 - 05:54 pm, by:  Drew Rechner (Drew1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Blake mate it sounds like you have a serious leak. When they refill the gas they place a dye in it and check with an ultra vilot light for leaks. They may have missed it. Best bet is that you take your car back to where you had it done and get them to check again for leaks. The only problem is, is that if you have a leak they will re charge you to fill it again.
Shaun Chiew
Reg: 11-2007
Monday, October 13, 2008 - 09:44 pm, by:  Shaun Chiew (Senk9) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had a leak in my Cressy that emptied it in 2 days. It was a big leak in the evaporator core (in the box located inside the dash). I bought a new core from a wrecker, fitted it and re-gassed it and now it's still cold 1 year later. Keep in mind this is after they ran the UV light around the engine bay and couldn't find it, so if your leak is in one of the hoses/o-rings in the engine bay piping, then that will be easier.
Good luck!
Matt Petersen
NA
Reg: 01-2008
Tuesday, October 14, 2008 - 04:11 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you look at the face of the compressor you should be able to tell the difference when it kicks in. Get someone inside the vehicle to turn on the AC whilst the motor is running and it should be obvious.
Matt.
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Tuesday, October 14, 2008 - 02:11 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Drew Rechner wrote on Monday, October 13, 2008 - 05:54 pm:
That dye only works for slow leaks (like 2-4 weeks minimum).
If it empties basically over night, then they'll need to pressurise the system and go over every joint with soapy water until they find the leak.
If they can't find the leak then there is a good chance its in the evaporater itself (ie, behind the dash). I have heard of quite a few Tx valves leaking.
Blake Davies
S A
Factory 5sp TT
Wednesday, October 15, 2008 - 08:19 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok. thanks..
how hard is to take out the evaporater ?
XTR T-66 Turbo
Wednesday, October 15, 2008 - 08:43 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its behind and kinda under your glove box. If you have ever changed/washed your AC filters you would have seen the very bottom of it.
AS for taking the sucker out.. i wouldnt try and cross that bridge till i REALLY had to
XTR T-66 Turbo
Wednesday, October 15, 2008 - 08:59 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Below are some heater core jobs just to get your blood pumping hehe
http://soarercentral.com/sc-forum/messages/31680/55434.html
http://soarercentral.com/sc-forum/messages/284/11788.html
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Thursday, October 16, 2008 - 07:15 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
take it back to the place that did it!
took them 2 gos to get mine right, but they found all the leaks and sorted it out.
Its not always easy to get it all straight away.
