  Soarer Central * Air Conditioning and Climate Control * My heater is only working when at high RPM Previous Previous    Next Next
Ben Smith
Reg: 07-2009
Friday, July 10, 2009 - 08:14 am, by:  Ben Smith (Bloodbath_ben) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok.. this just started happening yesterday, My climate control was working perfectly but since yesterday on Max heat or any other warm setting it was freezing - and I was getting a bit annoyed so I soothed this by planting my foot to the ground and all of a sudden I had warmth whilst driving fast... as soon as I got stuck in traffic it started to get freezing again... so... any ideas? Has someone had a similar problem? Water Pump? Blockage?? Any help would be appreciated :-)
Andrew Duaso
Reg: 02-2009
Friday, July 10, 2009 - 08:47 am, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i had the same problem, i thought it was the VSV and whatever else, it was driving me crazy!
then i checked the radiator water level and it was low..... topped it up and now it's fantastic :-)
Ben Smith
Reg: 07-2009
Friday, July 10, 2009 - 09:23 am, by:  Ben Smith (Bloodbath_ben) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good idea, I will check that out today! Thanks Andrew, I'll let you know how it goes.
Saturday, July 11, 2009 - 05:56 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben, also check for air by releasing the bold behind the thermostat.
Steve Latimer
UZZ32
Saturday, July 11, 2009 - 09:30 am, by:  Steve Latimer (Latsus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is that sorta like the bold and the beautiful????
Saturday, July 11, 2009 - 10:57 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Michael Marchant
Soarer UZZ32 V8 finished in Zymol goodness!
Saturday, July 11, 2009 - 11:32 pm, by:  Michael Marchant (Mavric) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any update Ben?
Ben Smith
Reg: 07-2009
Sunday, July 12, 2009 - 10:08 am, by:  Ben Smith (Bloodbath_ben) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, topped up my water and bingo, I am now enjoying warmth again! Thanks for all your help! Cheers
Monday, July 13, 2009 - 06:11 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmm, when I had that problem with my UZZ30 it was early warning signs that a gasket was on the way out. When I finally tracked down where the leak was it was a huge job to fix it. I was driving around for about a month constantly re-filling my coolant every time the heat dissapeared from the heater.
Ben Smith
Reg: 07-2009
Monday, July 13, 2009 - 07:27 pm, by:  Ben Smith (Bloodbath_ben) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That sounds scary.. head gasket was it? or something else.. I will keep my eye on it and hopefully it isn't anything serious.. thanks for all the feedback guys.
Tuesday, July 14, 2009 - 06:37 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No, it was an o-ring gasket somewhere near the water pump. It was covered by the mechanical insurance I had, so I have no idea what it cost to fix other than the mechanic told me he'd spent the better part of a day on it.
