Wednesday, July 15, 2009 - 12:01 pm, by: Joshua Fraser(Skelletor)
ok just bought a sc400 thats had a slight hit in the front...the AC lines were damaged and aren't connected atm,there all bent up and probably beyond repair.
I'm not overly fussed about AC,as long as the windows wind down...for the moment anyway.
But being such modern car with computerized everything will this affect me being able to get it running or not....I didnt think so but im just checking. thanks josh
Wednesday, July 15, 2009 - 06:08 pm, by: Peter Williams(Skeeta)
Josh, check with whoever is going to do your roadworthy cert. Mostly, if its on the vehicle it has to be working, but your rwc man might let you off a little bit. Bearing in mind that your AC is also used for demisting. I worked at Waubra for 6 months (wind farm related), so I know how handy the AC demist thingo is in your part of the world. Check out the for sale section on this forum and you will be able to pick up some second hand AC pipes from another member.
