  Soarer Central * Air Conditioning and Climate Control * Running water sound when driving Previous Previous    Next Next
Open in new windowArchive through January 21, 2006Peter Nitschke23
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Saturday, January 21, 2006 - 01:20 am, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
much better ;)
Mark Donovan
n/a
Soarer V8 Limited
Monday, March 27, 2006 - 06:51 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have the running water sound as well but always thought it sounded like it was coming from the dash in front of the passenger seat. Will try the air bleed trick at the weekend. Air con & heater is working fine otherwise, and definitely no water leaking in the cabin!
Michael Keen
Wednesday, March 29, 2006 - 03:27 pm, by:  Michael Keen (Jzz30man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark,
Haven't read thread above yours, but this may help.
Running water suggest your cooling system is not full, and has air in it. This could mean you have a cooling system leak somewhere, or your system was not full in the beginning.
The leak is most likely not going to be in your cabin, its likely to be in the engine bay somewhere. Potential locations: Small cooling hose to turbo or anywhere else (numerous), radiator, radiator cap, radiator hose, welch plug and head gasket are the common ones. Obviously head gasket is the worrying one, but not common with these engines like 7M engines.
Can replace the air with water by parking with nose up steep hill when engine is hot, heater & fan on, engine running. Let idle for a few minutes. Turn engine off. Let cool. Take radiator cap off and top up both the radiator and the overflow bottle to the correct level.
Then monitor carefully. Noise shud go away. If it returns, go looking for a source of a leak, which is potentially lethal to your engine.
JunkFilterer
Wednesday, March 29, 2006 - 03:32 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On a V8, ease out the bolt above the thermostat to see if it has air.
3.0 GT
Thursday, March 30, 2006 - 10:46 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think that'd make me wanna pee all the time...
JunkFilterer
Thursday, March 30, 2006 - 10:50 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Easing the bolt out? I didn't mean it like that!
Mark Donovan
n/a
Soarer V8 Limited
Monday, April 03, 2006 - 12:45 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the suggestions- will give it a go & look forward to successful results.
Norfolk Island
Thursday, April 27, 2006 - 03:10 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The Subaru Liberty made that gurgling/sloshing noise in the dash the entire 7 years I owned... in the end it was one of those "character" things:-)
Thursday, April 27, 2006 - 03:44 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm a "Character", and I slosh & gurgle when boozing
Dyon Gerlach
Reg: 12-2006
Tuesday, February 20, 2007 - 10:48 pm, by:  Dyon Gerlach (Dyon_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
Just had my water pump replaced and am now having the same water/air noise problem. Obvious suspect is trapped air in the heater core.
Did anyone find a proven method for bleeding/flushing the air out, other than parking up a hill ?
Active V8 and a Factory Manual XF.
Wednesday, February 21, 2007 - 12:05 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep.
Dyon Gerlach
Reg: 12-2006
Wednesday, February 21, 2007 - 10:42 pm, by:  Dyon Gerlach (Dyon_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats great !
Care to share with us how ?
Stewart Booton
uk
V8 ACTIVE 838
Sunday, February 17, 2008 - 01:04 am, by:  Stewart Booton (V84) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anyone? i have this problem now..
Richard Ferrara
Reg: 03-2008
Saturday, April 26, 2008 - 06:02 pm, by:  Richard Ferrara (426440) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Me too (after a water pump replacement).
