  Soarer Central * Air Conditioning and Climate Control
Open in new windowA/C blows out White Dust stuffNina Smart
Open in new window94 V8 UZZ31 Fan Speed Blower Resister LocationIan Hassall
Open in new windowNo power to ac unitDarren Driscoll
Open in new windowAircon not getting coldNatasha D'Abreo
Open in new windowClimate control unit lights up, auto temp lights up. but nothing on...Matthew Wielozynski
Open in new windowAir compressor stuffed?Boris Siljanoski
Open in new windowBlower not workingJoe Russell10
Open in new windowV8 & 1j AC air compressor The same? Boris Siljanoski
Open in new windowAir con thermal switchVic Olbromski
Open in new windowNEED EVAPORATORBoris Siljanoski
Open in new windowAir-con compressorsBoris Siljanoski
Open in new windowReplacing A/C Compressor?Boris Siljanoski
Open in new windowA/C Code 23 and 41Boris Siljanoski15
Open in new windowClimate control fan speedIan Hassall10
Open in new windowHow Hard/Time Consuming Is It To Take Off The CompressorDamien Barnes10
Open in new windowCold air not coldBoris Siljanoski
Open in new windowAircon smells like pee (for first 10 seconds)David Grab18
Open in new windowAir Purifier SystemDavid Grab16
Open in new windowCondenser and Drier ReplacementRaj Somarouthu
Open in new windowAre the climate controls units the same on Soarers if its of the sa...Matthew Sharpe13
Open in new windowHow to fix vsv valveMatthew Regan11
Open in new windowProblem In 2010Brian Rignall
Open in new windowNeed help identifying this part!!!Boris Siljanoski15
Open in new windowHychill Regas in Perth?Boris Siljanoski12
Open in new windowAircon not coldBoris Siljanoski
Open in new windowFan speed either really low 1-2-3 .. or full on 4.. Matthew Tai
Open in new windowTrying to diagnose A/C problemBoris Siljanoski
Open in new windowReccomended amounts of oilBoris Siljanoski
Open in new windowTX VALVE STUFFED, whats the part number for new one??Boris Siljanoski
Open in new windowHeater questionJohn Jantzen
Open in new windowWooing Noise during DriveBen Lipman23
Open in new windowNo Heat?!Shamus Lee
Open in new windowPulsating airconDaniel Blackham12
Open in new windowDo regulators leak?Boris Siljanoski16
Open in new windowCelsior Evaporator Replacement, where to buy ?Frank King
Open in new windowAirCon Regas in BrisbaneTim Ross
Open in new windowCLIMATE CONTROLEDavid Vaughan
Open in new windowClimate control no logner works after manual covnersionSimon Jackson
Open in new windowAircon condenser replacemnet Raj Somarouthu
Open in new windowCompressor interchangeable 1jz - 2jz?Josh Totall
Open in new windowAir con drainSeamus Brice-Bennett
Open in new windowFan runs flat out regardless of settingMatt Petersen
Open in new windowCompressor continually engages then disengagesAndrew Stewart
Open in new windowBy passing heater matrixPeter Barrett
Open in new windowHychill minus 30 anyone used it?Tom Richards
Open in new windowClimate control stuck on hotRob Rojo
Open in new windowClimate control modification : cold cathode backlightMichael Larcombe
Open in new windowAir con unit not working.Tony Gadd
Open in new windowHow long to change TX valve? $$$$$$?Steven Roduner
Open in new windowAC Blower fan not workingRob Rojo
Open in new windowCan the car drive with CC unit out?Matthew Tai
Open in new windowEvaporative Dryer Part #Tony Fenech
Open in new windowHeater/AC issue: Vents blowing dust -> where is it coming from!?Matthew Tai
Open in new windowDoes my AC need to work??Joshua Fraser
Open in new windowMy heater is only working when at high RPMMatthew Sharpe11
Open in new windowLeaking from EvaporatorBoris Siljanoski
Open in new windowAir Conditioning Lighting??Paul Mainey
Open in new windowNo a/c settings on my scrrenEugene Baker
Open in new windowHeater air only warmJustin Cook
Open in new windowClimate control works but temp nob not working??Jack Oliver
Open in new windowAir Con Light but no cigarMark Wright26
Open in new windowClimate Control Not WorkingLouis Angelopoulos
Open in new windowClimate control unit not working fuse locations?Jack Oliver
Open in new window91 UZZ31 limited heater core infoPeter Williams
Open in new windowIs it bad that my v8 runs cold?Brenton Trafford
Open in new windowClimate control stopped working.. :-(Danny Watson
Open in new windowClimate Control Swap TT <-> NAMatthew Tai
Open in new windowEMV to Non EMV Climate Conversion - Complete WalkthroughLuke Gomer27
Open in new windowHeater tap leakingJames Cahir
Open in new windowNew UZZ31 owner, these buttons dont work.Luke Gomer
Open in new window$4000 quoteDaniel Lee
Open in new windowWeight reduction, air con removal, issues?Daniel Clarke13
Open in new windowDo A/C compresses swap between different models?Michael Crimp
Open in new windowVSV Valve changeGabriel Fortin-H.
Open in new windowAC problems... & yes probably been done beforeRyan Rankovic30
Open in new windowEMV heater control, how to turn on?Jason Lenz
Open in new windowAC LCD TT SOARERHarley Jones27
Open in new windowAir Condition Fan Not RunningHarley Jones
Open in new windowClimate control backlightingLawrence Ostle
Open in new windowBlower fan brokenKurt Harrison
Open in new windowSoarer Air-Con Specialist in Adelaide.Blake Davies13
Open in new windowIs my a/c display leaking? :-(...Kane Chan
Open in new windowAircon regased... 2 days later ... no more airconChris Round17
Open in new windowAircon re-gas in PerthJeremy Morton
Open in new windowReplacing fanJeremy Morton
Open in new windowI well broked mine! (Thread in story mode)Matthew Standage26
Open in new windowSourcing new AC condenser for 91 V8Gary Kosmopoulos
Open in new windowSoarer Air conditioning experts in SydneyMichael Brogefjord
Open in new windowBlinky a/c button light.Harry Lemmens
Open in new windowWhere is the VSV valve on a RHD soarer?Matthew Standage20
Open in new windowAIR CON FAILAdrain Parsons
Open in new windowA/C Light blinking & No cold airRichard Baird33
Open in new windowReally annoying problem with interiorAdam Lonergan
Open in new windowRomoval of the compressor?Jason Munro
Open in new windowHelp!! aircon ON and OFF..Error code 21???Dave Hart
Open in new windowWorn out Compressor?Justin Green11
Open in new windowAircon probelm. HELP,,,Blake Davies10
Open in new windowAir con not workingVinny Ozorio
Open in new windowCelsior Heater Problem HOTJames Walker
Open in new windowEMV A/C Diagnostic test screen in Japanese who can read Image AttAhtoh Di
Open in new windowAir Con stuck on Full...Matt Petersen10
Open in new windowAfter 6 Months of A/C R & D it was a dirty connection.Luke Gomer
Open in new windowNeed Help Diagnosing my AC ProblemBrett Harrison
Open in new windowPN for AC compressor in 91 V8Tom Richards
Open in new windowClimate Control occationally switches to 25.0 degreesJames Harris
Open in new windowWeight of gas in systemSebastian Grant
Open in new windowPart numbers for A/C hose and valveDon Bagnall12
Open in new windowResistor codes for aircon?Brett Harris
Open in new windowAircond use without EMVFran Valdivia
Open in new windowSmelly Air ConditionerBen Dowdell14
Open in new windowHeater CoreMichael O'Driscoll17
Open in new windowHeater TapDon Bagnall
Open in new windowSoarer friendly A/C repairsMichael Crimp
Open in new windowNo heat just ice cold air... baahhhNye Phillips13
Open in new windowHeater goes cold when car stopsPeter Nitschke18
Open in new windowFan only works with A/CPeter Nitschke11
Open in new windowFan speed - Airflow stays same on all settingsDon Bagnall15
Open in new windowFrosted pipe. Is this normal?Dave Rose
Open in new windowVSV ValvePeter Nitschke
Open in new windowSoarer Air Condition Specialist in AdelaideDrew Rechner
Open in new windowSoarer Air Con Cooling CoilPrem Ananth Ganesh
Open in new windowLocation of interior/exterior temp sensor for ACPeter Nitschke
Open in new windowAC pressure regulatorSeamus Brice-Bennett
Open in new windowNo air through center ventsMichael O'Driscoll
Open in new windowSoarer Air Condition Specialist in MelbourneDaniel Lee12
Open in new windowHeater Core Leaking, some quick help?Michael O'Driscoll23
Open in new windowYet another a/c question...Nye Phillips
Open in new windowAir Con Parts - Where to source them threadBrendon O'Loughlin
Open in new windowAircon button flashingNye Phillips20
Open in new windowReticulated AirMichael Keen13
Open in new windowHeater only works on "max heat"Tom Richards
Open in new windowNot Runnig the ACDave Hart
Open in new windowBypassing HeaterPeter Lang
Open in new windowGas Leak ?Jason French10
Open in new windowHeater leak problemBrenton Trafford
Open in new windowAir Con Wiring Diagram?Evan Kaio15
Open in new windowRunning water sound when drivingRichard Ferrara37
Open in new windowA/C compressor bearingsBen Richardson
Open in new windowAC light blinks after ~10mins, AC still coldMark Northcott
Open in new windowError code 14 & 21Anuradha Vithanage
Open in new windowA/C Magnetic ClutchAshley Leach
Open in new windowAir con working, but not working..Rich O'neil
Open in new windowHeater Not WorkingAndrew Stewart19
Open in new windowSuper Chill Aircon GasDrew Rechner48
Open in new windowUCF11 Celsior. AC not engaging the hydraulic fan.Aaron Mead
Open in new windowWeird hose leak (to auxiliary motor?!?)Matthew Sharpe14
Open in new windowIdle speed with A/C on - is it easy to adjust?Damian Ware
Open in new windowHeater tapAlan Chow
Open in new windowVSV Seems okay, but only warm heat Peter Nitschke
Open in new windowAir con computer?Danny Minns
Open in new windowAC BacklightAndrew Beshara13
Open in new windowAir con place on gold coastSam Avery10
Open in new windowSmoke from exhaust when AC onDave Rose14
Open in new windowWhere is the tx valve?Daniel Czechowski49
Open in new windowA/c pulley probs?Matthew Sharpe
Open in new windowHeater Core BypassPeter Nitschke
Open in new windowCan you still regas the old Soarer systems with old gas?Adam Peterson40
Open in new windowInstalling the CondenserAdam Peterson
Open in new windowAircon Cutting off and on randomlyPeter Nitschke
Open in new windowAir Conditioner FiltersDrew Rechner13
Open in new windowA/C lcd display scrootedAndrew La'Brooy10
Open in new windowLocation of tx valveVanessa Hassell
Open in new windowHELP I'M HOT!!!Patrick Robinson
Open in new windowAirConTravis Bentley
Open in new windowPassenger's A/C feet ventsJonathan Hong
Open in new windowAir flow stay in FULL (Solution)Peter Nitschke
Open in new window2nd hand heater tap?Chris Quirk
Open in new windowHeater Control Thing (On Firewall)Andrew McKenzie16
Open in new windowStrange Air con problemAndrew Ferres23
Open in new windowExternal temperature sensorGary Morriss
Open in new windowAir Con problems after replacing LCD head unitLew Radbourn
Open in new windowAircon not as cold after fmic installGraham Dollisson
Open in new windowAircon compressor?James Leedie
Open in new windowR12 in a canMiles Baker
Open in new windowIs my compressor cactus?James Leedie
Open in new windowWeird air conMatt Smith
Open in new windowA/c lcd lighting issueBill Terry
Open in new windowEMV/Non EMV Are they different Air con Computers?Neil Griffiths23
Open in new windowRough price on how much to fit TX valveChristian Zimmer
Open in new windowInfo on 92 TX valve pleaseMel Clark
Open in new windowEvaporator temp sensorMark Ribbans
Open in new windowHelp me turn it on, I'm cold!!!! Anthony Jowett
Open in new windowCan you run aircon while the windoes are openPeter Nitschke23
Open in new windowRadiators- Cost to replace/repair? in QLDTom McGruther
Open in new windowHeater (what The)Damien Murray
Open in new window1UZ A/C CompressorMark Northcott
Open in new windowMy car gets all warm inside even when temp is on "MAX COLD"!Neil Griffiths55
Open in new windowHR12 Charge weight for the soarer Clayton Webb
Open in new windowAux fanCliff Newton
Open in new windowA/c Compressor Part NumberAshley Leach
Open in new windowAir con compressor for a 2jzSteve Gorman
Open in new windowHow to remove glovebox?Peter Nitschke
Open in new windowHelp Aircon Not giving me climate haha only ice air.Mark Paddick11
Open in new windowA/C Compressor - where in Brisbane?Daniel Lee
Open in new windowCelsior aircon not workingMark Paddick
Open in new windowClimate ControlPeter Nitschke
Open in new window21 - Solar Sensor CircuitMark Paddick
Open in new windowAic Con in AdelaideAshley Leach
Open in new windowAir con unit?Bill Bogiatzis
Open in new windowAircon problemShaun Luckhurst
Open in new windowCost of Retrofit and a Reconditioned compressorAshley Leach
Open in new windowNo Heater!!Joe Radisic
Open in new windowAircon compressor run timeClayton Webb
Open in new windowAC Getting fixedAshley Leach
Open in new windowWhat is this?Paul Bernasconi
Open in new windowA/c takes a while to coolAndy Xie
Open in new windowTT soarer compressorJustin Cook
Open in new windowEvaporator temp sensorPeter Nitschke
Open in new windowFan Not Running?Dominic Kelly
Open in new windowFrozen pipe?Dan McColl
Open in new windowDegrees C displayPhil Stuart
Open in new windowTx valve on 92 V8 soarer, anybody know where situated?Mel Clark
Open in new windowRegassed many times, no leaks found, but no cool air once againMatthew Sharpe12
Open in new windowJust My Luck........Heater Core.....Nathan Herbertson17
Open in new windowA/c repairer in sydneyJan Christiansson
Open in new windowNo HeaterDaniel Lee12
Open in new windowCommon leak points for gas?Nathan Stringer
Open in new windowBlacked out Climate Control PanelFred Azzarello32
Open in new windowAir con button blinks sometimes and disengages compressorSeamus Brice-Bennett
Open in new windowSide ventsMatthew Sharpe
Open in new windowVSV ValveJoe Aliano
Open in new windowWeird ProblemVinh Bui
Open in new windowNo backlight for the LCD displayPeter Nitschke
Open in new windowRunning AC while emptyMike Mortimer
Open in new windowSmoky A/CPeter Nitschke18
Open in new windowFoam spitting outCallum Finch
Open in new windowClimate/AC globes??Mike Mortimer
Open in new windowA/C CompressorRob Foster
Open in new windowHeater Core - How much?Michael Sinay
Open in new windowTurn A/C off and I can hear a cap-gun soundMike Mortimer
Open in new windowOutside air temp sensor not workingTai Johnsen
Open in new windowError 41Delan Peiris
Open in new windowNo Heat In Car: Solenoid Replaced - Is it my control unit?Delan Peiris
Open in new windowAir Con SpecialistMichael Bagshaw26
Open in new windowAir-con QuestionsSam Schreck29
Open in new windowMusky smell in A/CVinod Param33
Open in new windowNo COLD air when Aircon is turned onPeter Nitschke
Open in new windowAir Con Place in Adelaide?Brenton Trafford
Open in new windowFirst post and air con wiring problemMark Paddick
Open in new windowHow AC worksAndreas Niaouris
Open in new windowWhistling ventDon Bagnall12
Open in new windowA/C crapin upPaul Drane
Open in new windowAir Con problemsRick Gualano
Open in new windowA/C Pressure SwitchDan McColl12
Open in new windowAir Con Compressor BearingCliff Newton
Open in new windowFilter part number?Peter Nitschke
Open in new windowHow does the Auto Air Button WorkShom Bhattacharjee18
Open in new windowNot coolCliff Newton
Open in new windowAir-con compressors?Khalid Sarwari10
Open in new windowEngine Idle Speed with air con on??Clayton Webb
Open in new windowCelsior A/Con filtersBrett Cashmore
Open in new windowAC regassed but still not workingThads Cooke
Open in new windowAIRCON EVAPORATORHaydn Crandell12
Open in new windowAir Conditioning issues - Air con only comes on at max cold - even ...Tom McGruther
Open in new window Solar Sensor's Purpose?Clayton Webb12
Open in new windowAir Conditioning HoseDan McColl
Open in new windowA/CBenny Gammelmark
Open in new windowAir ConAlan Chow13
Open in new windowWhats this?Peter Nitschke13
Open in new windowA/C power usageLuke Middleton13
Open in new windowIS HR12 available yet?Clayton Webb
Open in new windowCOLD..!!! Heater doesnt work...Delan Peiris15
Open in new windowCondensor??Gil Harding
Open in new windowAir Conditioning GasDaniel Lee13
  Start New Thread
  Administration Administration      Log Out Log Out
