Wednesday, December 28, 2005 - 10:06 pm, by: Clayton Webb(Clackers)
Just wondering what idle speed it should be at with the air con on? Mine only sits at 700 with it on while in Park. Is the A/C idle speed controlled by the computer or a solenoid??? Thanks in advance.
Wednesday, December 28, 2005 - 11:42 pm, by: Dan McColl(Hoon)
Yeah, It's controlled by the idle air control valve. Run a search to find out common problems or check out planet soarer, http://planetsoarer.com/IAC/iac.htm Scotty has just rebuilt his.
Also, try a ECU reset, might help.
BTW, Mine sits at 750 all the time when warm, air on or off, PRND2L.
