  Soarer Central * Air Conditioning and Climate Control * PICS of my evaporator and tx valve work.. Previous Previous    Next Next
Matthew Werner
jzz30 T
Reg: 12-2006
Monday, February 27, 2012 - 09:42 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys. cleaned evap and replaced tx valve. (admin feel free to move or copy to how to's at your discretion)
tx and evap core located behind glove box.. pretty self explanitory on how to remove the glove box...
**** GET YOUR A/C DISCHARGED BY A WORKSHOP PRIOR TO REMOVING ANY PIPING****
oopss dunno how tenit pheonix got in there.... oh well...
i had a decent size leak where its marked on the evap core, all seals were replaced using r13a stuff and all pipes were cleaned out...
make sure you get a workshop to regas with oil and dye when you have everything bolted back together properly.. anything over 3-400 for a regas is B/S and you should get a quote elsewhere..
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Tuesday, February 28, 2012 - 11:35 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jolly good show. Much appreciation for the effort.
Tom Richards
Wednesday, October 29, 2014 - 02:34 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
good info above, just changed my TX valve. couple of hrs, straight forward job. temp in vents before changing was 8' min, it is now 1.5' min.
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Wednesday, October 29, 2014 - 06:49 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just to confirm, were gas levels optimal before TXV Change?
Great result.
Tom Richards
Thursday, October 30, 2014 - 07:35 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes levels were correct before the tx was changed. A regas had showed a large pressure drop in the system which indicated the TX valve was faulty, coldest temp reached was 8'.
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Saturday, November 01, 2014 - 12:28 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Which model TXV did you get, was it aftermarket?
Tom Richards
Saturday, November 01, 2014 - 09:12 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
correct part from toyota.
