  Soarer Central * Air Conditioning and Climate Control * AIR CONDITION COMPRESSOR 1JZ SOARER Previous Previous    Next Next
Andrew Sharkawi
Soarer TT MANUAL
Reg: 09-2009
Wednesday, December 19, 2012 - 02:42 pm, by:  Andrew Sharkawi (Bishoopowers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hello everyone, my compressor is finished. when i press my ac button its make a loud sound, and then goes away, not cold air comes out its just normal fan on blowing out air..... SOOOOO i need a new compressor...... BUT... i need one that is SUITABLE for my car (1JZ)im pretty sure you cant use the V8 compressors... i have heard compressors are like 600..DOLLARS... SOOOOO if anyone cane PLEASE help me and tell me what to do in this case, link me to a site or tell me someone who is selling a second hand one that would be much appreciated.
THANKS- ANDREW
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Wednesday, December 19, 2012 - 09:25 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Andrew,
How do you know the Compressor is finished, is the noise a loud squeal like belt slipping?
When the car is off, can you spin the front part of the compressor (Clutch), not the Pulley itself but the part infront of it.... does it spin at all or is it Frozen in place?
You have 2 Options. New is about $600 like you Said.
Remanufactured can be as cheap as $150 upto $300. And there is no Definition of Remanufactured.
I have talked to all the Ebay sellers that sell Re-manufactured Compressors... and what is changed varies.
Some only Change the Seals.... and everything else is left the same, e.g if it's not broken or seized, they don't replace it. So a lot of the Remanufactured Compressors use old parts... there are some parts you can't replace though.
Other Places will Replace Seals and Bearings Too. and Cost Usually ends up being Higher.
Many people have had no problem with Remanufactured Units.... but also there have been people who have had Failures.... some Due to bad Compressors... but some due to Underlying problems.
The best would be a Brand New Unit in my Opinion just for piece of mind.
You also have to Ask yourself why the Previous Compressor Failed.... because most of the time compressors fail because of :
- Blocked TXV Valve
- Sticking Open TXV Valve
- Lack of Oil
- Heat (from Excessive High Pressure)
- Lack of Refrigerant (Leaks)
So any of the Above problems need to be Ruled out. If you just whack a new compressor in and Regas it, chances are it will fail again soon.
Alexander Green
Soarer Jzz30 GT-TL
Reg: 03-2012
Saturday, January 12, 2013 - 09:02 pm, by:  Alexander Green (Greeno) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i got a denso unit from the U.S off the denso website, cost was under $500 from memory including postage and only took about 1-2 weeks to arrive. They don't have a listing for a 1jz but the 2jz units are identical except you just have to change the top plate (where the gas fittings are, only 4 bolts) with your old compressor as they just come with a blanking plate there.
I also have a second hand one for sale but im not sure of its condition, its out of a soarer im wreaking and forgot to test it while it was running before i sold a few engine bits, so now the engine doesn't run so cant test...there is still gas in the system so i can only presume it was working ok....I'm in QLD also
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Saturday, January 12, 2013 - 09:24 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Alexander PM Austen Menze he is after a spare compressor.
Andrew Sharkawi
Soarer TT MANUAL
Reg: 09-2009
Tuesday, January 29, 2013 - 02:15 pm, by:  Andrew Sharkawi (Bishoopowers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
okay i found and bought a 1jz ac compressor from Miami for 50 dollars although was 100 for postage.. =/
well i guess its alright price, but just got to install, re-gass and see if it works thumbs up :-)
