  Soarer Central * Air Conditioning and Climate Control * Location of the Aircon Compressor Relay? Previous Previous    Next Next
Chatura Mudi
V8 Limited Active
Saturday, April 13, 2013 - 02:43 pm, by:  Chatura Mudi (Chatu) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi All,
I wad checking every where on the forum to find out where is the aircon compressor relay is but I couldnt.Can some one please tell me where is it located.
My aircon not working anymore and compressor not kicks in.
Friday, April 19, 2013 - 01:12 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Probably low on gas as that causes it to not switch.
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Friday, April 19, 2013 - 04:21 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try Middle row of Relays on Engine bay Fusebox, 2nd from the left next to a Circular Relay.
To Confirm this :
1. Trace the wire coming off the Magnetic Clutch for the A/C Compressor and note which wire it is on the 3 Wire Plug ontop of the compressor.
2. Unplug the 3 wire plug ontop of the compressor and with the Multimeter on Resistance or Continuity Mode insert one probe on the wire that supplies power to the Magnetic Clutch.
3. Remove the Relay suspected to be A/C Compressor Relay and probe all 4 of the Terminals on the slot until a link is shown.
The A/C Compressor Relay normally does not become faulty and it is more likely you are low on refrigerant or the compressor clutch coil is shorted or open or a faulty pressure sensor.
When taking the gar to be re-gassed, ask the mechanic/technician to check for leaks from the Compressor and every joint/fitting. If the compressor is found to be leaky it needs to be removed to check oil level.
Chatura Mudi
V8 Limited Active
Sunday, May 05, 2013 - 10:57 am, by:  Chatura Mudi (Chatu) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks All.Its fixed.You are right Peter,it was gas..
