Wednesday, December 04, 2013 - 02:04 pm, by: Joe Trojan(Jttt)
Well I think my AC system is losing gas, but I think something else is going on.
The cold pipe just doesn't frost up anymore and the system doesn't cool anywhere near as when freshly re-gassed. I noticed a slight improvement after I re-installed all the cooling fans,
however:
Yesterday after 4.5 hours of driving, 1 of which was in a huge traffic jam on the Hume Hwy, I noticed the compressor only cuts in for a second or so, then disengages for 10 sec or so, then retries, only to then stop again, and keeps repeating this cycle but varies in time a bit.
Today with everything cooled down, the AC works again and the compressor stayed engaged, but I'm sure when everything heats up the compressor will disengage like it was yesterday. No warning lights or anything on the climate control display.
Are these symptoms consistent with just low gas, or is there something else going on? I've basically been through every thread in here but any further "common problem" suggestions much appreciated. In the meantime I'll get hold of a UV light and start looking for leaks.
Saturday, December 28, 2013 - 12:56 pm, by: Joe Trojan(Jttt)
OK so on a long drive at night last Monday I get the dreaded flashing AC light, with added obvious successive engine load/unload cycles (while cruising at 110kph/2500rpm) which tells me my compressor is seized.
I think on top of a possible leak, when I got the system re-gassed the guy did not flush the system. The high side restriction was probably from a blockage caused from crap from the previous original compressor which was very noisy, which also killed this replacement compressor in 3 months/less than 10,000kms.
So my mission is to swap the evaporator and tx valve with the parts from my '91 wreck (which had working AC), replace all o-rings, get everything flushed, install a new compressor, get re-gas with extra flush done from an actual AC specialist in a shop, (not some guy in a mobile truck in a rush to get to the next job), confirm they will use the correct amount of gas before they start, get them to test for leaks on the day and again 3 or 4 weeks later.
Saturday, December 28, 2013 - 05:06 pm, by: Greg Wyllie(Bearshead)
Joe, the guy I suggested, above, is a mobile service however he has never been in a hurry when I have used him. My '31 a/c has been working exceptionally well in this hot and humid days
Sunday, January 05, 2014 - 01:28 pm, by: Joe Trojan(Jttt)
Boris I havn't done anything. I planned to get onto it after nye but the ac compressor is now seized (can't turn it by hand). To do tests now requires re-installation of a working compressor and a regas anyway. I do have the original working but noisy compressor sitting here.
Is there anything that can go wrong other than leaks, compressor and the tx valve?
Tuesday, January 14, 2014 - 12:45 pm, by: Joe Trojan(Jttt)
Boris, I just read your posts in the LPG thread. Your overflowing pile of knowledge has given me some much needed confidence. I might start on swapping over the compressor today.
