  Soarer Central * Air Conditioning and Climate Control * A/C Compressor Previous Previous    Next Next
Rob Foster
TAS
Sunday, April 30, 2006 - 11:51 am, by:  Rob Foster (Freelance) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can anyone tell me the best way to get a replacement Compressor for a 2001 LTD
Any help appreciated
TKS
Rob
Sunday, April 30, 2006 - 12:51 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it's a 91 model Neil
Dave Hart
Waikato
UZZ32
Sunday, April 30, 2006 - 02:50 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you're going the s/h route be sure to check whether you need one with a speed sensor or not, some of us on this site have been caught out in that regard. Also check whether you need to replace the clutch on it as the price quoted for a new compressor will be sans clutch.
Tony Chen
Reg: 12-2005
Monday, May 01, 2006 - 12:49 pm, by:  Tony Chen (Tchen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if is a seized compressor can be reco but noisy slapy piston.
if used you need to reco all the seal to a R13A before installation. as hardly anyone can benchtest commpressor they need to a 150psi to 200psi as the shaft seal is the hardest i stuff it twice made of carbon & can crack fingers X
and last its new if you got the bread.
Rob Foster
TAS
Wednesday, May 03, 2006 - 12:28 pm, by:  Rob Foster (Freelance) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Many thanks guys. Its almost winter down here now so Ill keep an eye out for a s/h (And turn the heater on)
