  Soarer Central * Air Conditioning and Climate Control * Air Con stuck on Full... Previous Previous    Next Next
Shane McInnes
JZZ30 GT-TL Manual
Monday, July 17, 2006 - 05:00 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey
Ok while my car was in the work shop for 3mths at the beginning of the year, i sent the Air con unit to Mark to get led lights put in. I got the car back and noticed that when you turn the Air con on or Heater on...you can adjust how much power you want but whats coming out of the vents is not changing just stuck on full ball. Also you press the buttons on the Air Con unit and does not make any sound at all.
Can someone tell me what needs to be done to fix it or have any suggestions? Id like to have the heater on but not full ball its quite loud and annoying, then its to hot. lol
I got my mechanic to check all the plugs back there, he said there all pluged in. So i dont think its a loose plug anywhere.
Mark Paddick
Monday, July 17, 2006 - 06:41 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Some A/C units beep and some don't. The later white housing one's don't.
The fan stuck on full is either a fault in the A/C unit (I couldn't test for that but can now) or the power transistor (separate to A/C unit) is shorted.
Shane McInnes
JZZ30 GT-TL Manual
Monday, July 17, 2006 - 08:06 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark ive sent you a PM ok. Regarding what i sent you at the start of the year.
Shane McInnes
JZZ30 GT-TL Manual
Monday, July 17, 2006 - 08:21 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used to have a black one. I recieved a white one back from you Mark, So i guess thats why it dont beep no more when i push a button So thats that problem solved. Any Chance that the one you sent me back had a fault in the Air Con Unit and you didnt realise?
Kyle Wathen
GTTL
Reg: 02-2007
Thursday, August 14, 2008 - 10:40 pm, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am having the same problem Shane, did you find the issue?
Matt Petersen
NA
Reg: 01-2008
Friday, August 15, 2008 - 04:31 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Resurrecting an old thread Kyle.
When I bought my Soarer I had the same problem, fan speed controls don't work so I got replacement resistor and transistor modules and installed them with no change.
I did a bit more research and looked at the wiring diagrams and there was a change about 95ish I think, could be earlier or later, and even though the connectors are identical the pinouts and controls are different and this will cause the unit to run the fan at full speed.
If your's is an earlier model then it's possible that you have a later control module fitted. When my screen went out the previous owner got a second hand unit from a later model and fitted it.
Matt.
Kyle Wathen
GTTL
Reg: 02-2007
Friday, August 15, 2008 - 09:41 am, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry Matt, forgot to clarify mine is stuck on the lowest setting not the highest.
The thing is the fan speed settings had always worked and then one day it just stopped working when I went to alter the fan speed.
So I dont think the wrong computer model would be the issue. More so that something has just failed? Everything else works as normal though still.
The unit still beeps when I press the fan buttons too.
Matt Petersen
NA
Reg: 01-2008
Friday, August 15, 2008 - 11:17 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's likely to be the resistor module then. You can pull the module and test continuity across the pins to see if it's faulty.
Andrew Keddie
vic
2.5TT soarer
Reg: 02-2008
Friday, December 19, 2008 - 09:03 pm, by:  Andrew Keddie (Boozer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i know its an old thread, but where is this resistor module. has anyone got any idea/pics???
Matt Petersen
NA
Reg: 01-2008
Saturday, December 20, 2008 - 04:11 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Remove the glovebox to get to the blower setup.
The resistor module is easy to find, it's a screw in module with some wires coming off it.
