  Soarer Central * Articles of Interest * Ball Joint Repairs Previous Previous    Next Next
212Kw @ 8psi MANUAL Super Charged UZZ31 :-)
Wednesday, November 01, 2006 - 02:45 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had a thought so I went a lookin, This may be the cheaper alternative to getting used arms etc.
Don't know what the prices are or if they can do em, I just looked for em, ok.
So it's up to you's to contact them if you need lower arms because of the ball joint failure.
A Ball Joint Restorer
Unit 2/ 15-19 Wylie St Toowoomba QLD 4350
ph: (07) 4632 3930 Motor Replacement Parts
Ball Joint Injection Service
36 Nelson St Cairns QLD 4870
ph: 0413 745 149 Motor Engineers & Repairers
Ball Joint Repairs
19 Stoneykirk Loop Kingsley WA 6026
ph: 0409 292 580 Motor Engineers & Repairers
Toan Nguyen
Wednesday, November 01, 2006 - 04:47 pm, by:  Toan Nguyen (Soarer_gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They're not in VIC =(
Anish Varsani
V8 UZZ30
Wednesday, November 01, 2006 - 06:18 pm, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They drill them, drill and tap the hole, put a grease nipple on then inject a resin that dries to form a hard rubber. If the joint gets noisy, it can be greased later down the track.
Kevin Cameron
Celsior
Reg: 02-2007
Tuesday, July 31, 2007 - 08:08 pm, by:  Kevin Cameron (Kevin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had this done in NSW to my tie rod end and they give a 40000k, 2 year warranty. He told me recently did the lower ball joint of a Soarer on the car without removing it. From memory he said this was $120, which is cheaper than buying one and without having to remove it. I think it was towards the Mona Vale area, but will get all the details if anyone wants them.
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Tuesday, September 30, 2014 - 07:52 am, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Kevin, I would be most interested in this company, do you have there details thanks.
