  Soarer Central * Articles of Interest * WARNING Ebay - Shonky Catch Can Previous Previous    Next Next
Mustafa Akgul
JZZ30-GTTL
Wednesday, September 28, 2005 - 10:53 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im posting this warning as i wanted to see what these oil catch cans on ebay are like..
well pulled one apart today and i have to say very bad.once i popped the lid off i discovered there was no filtration device at all.nothing.so first up its useless.
secondly from chroming the can the inside of it had metal flakes ready to come loose and go into your turbos and engine possibly causing damage.not good.
the point is you get what you pay for.but would lose much more through such dodgy parts.
you have been warned stay clear.
below are some pics of the inside.
metal flakes left of picture
no piping or filtration devices
Akan Kirkbright
Yorkshire
Saturday, November 19, 2005 - 03:26 am, by:  Akan Kirkbright (Frankly) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Who was the seller.
Ben Evans
Soarer T
Wednesday, December 07, 2005 - 11:43 am, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i got the same one, though the chroming wasnt peeling on mine and i just threw some steel wool in there to filter it.
Still cant work out the 3 inlet/outlets.
Im assuming, the bottom one is for return line to sump, one top one for air intake, and the other for cam cover?
for $40 i cant complain though
Justin Camilleri
1985 MZ10, 1992 TT, 1991 TT
Wednesday, December 07, 2005 - 10:51 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
are those the greddy copies?
Emanuel Spinola
JZZ30, UZZ32
Wednesday, December 07, 2005 - 11:14 pm, by:  Emanuel Spinola (Manny) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oil/air separators don't need physical filtration media to separate the oil from the air.
The Greddy style cans rely on gravity and the 180 degree turn to separate the oil and trap it - has worked effectively for my Soarer engines over 4 years now.
Apparently on some poorly designed cans where physical filtration media is used, it is prone to either overwhelming the filter media and blocking the crankcase ventilation system and popping hoses or the media breaking down into smaller pieces and being passed back into the engine where it can do more damage to the valvetrain and rotating assembly by clogging oil drain passages, or lodging against moving parts wearing them down prematurely.
