  Soarer Central * Rush Imports * Clutch to suit w58 1uzfe Previous Previous    Next Next
Casey Perkins
Tasmania
Reg: 08-2011
Thursday, November 10, 2011 - 06:09 pm, by:  Casey Perkins (Caseyp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Neil just curious about getting a new clutch for my Soarer but as its a conversion I don't know where to start, would I need to get a custom made clutch ? Any help would be greatly appreciated, thanks :-)
Also what is the go with your headers to suit a manually converted 1uz ? Thanks again
Specs are a w58 gearbox with standard 1uzfe flywheel ( I think )
Friday, November 11, 2011 - 06:10 am, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Casey,
You will have to take the friction plate and cover plate to a clutch shop to match them up, they will be from alternate cars ( Eg Cover plate from Hilux / Friction from a Valiant )
My Extractors WILL NOT clear the slave cylinder on the side, BUT, if you install a Concentric Slave.
http://www.australianclutch.com.au/page.asp?parentid=114&productid=23
http://www.clutchpro.com.au/page.asp?parentid=4&producttype=1&productid=44
The Extractors WILL fit :-)
