Rich O'neil
Tinkerer Queensland 90 Celsior
Posts: 38 Reg: 05-2006
| Finally got the S/S filter adaptor done and fitted , went straight in first go , will alter the angle just a bit to centralise it a little bit more but very pleased . It has had an effect on performance , it's quite a bit crisper , even my wife commented on it , I've no doubt that it will have increased the HP a bit but it's hard to tell as I don't normally go around using max HP so a little bit more won't be noticed . Will be nice not to have to fork out $35.00 for a new filter every 3 Mths . I've only had two tankfuls through it since it was installed , but so far the milage is up by 50 K's a tankful , normally get about 500 K's out of a tank around town , the last two have been just over 540 K's , very appy !!
Rich O'neil
Posts: 40 Reg: 05-2006
| Have now had it all out and finish welded it as well as making up a jig so that I can reproduce it exactly .
Ryan Posselt
Tinkerer NSW Celsior V8
Posts: 41 Reg: 08-2006
| Thats awesome Rich, Great Job. Question... can you work out your L/100kms with the new filter. as i have recently fitted one of those vortex generators as well as a trust airnix filter to go in the stock panel position and i'm getting 13.6L/100km which translates to about 600kms for the best part of a tank. just wondering if i should upgrade to what you've done or not for consumption reasons CHEERS |
Rich O'neil
Posts: 46 Reg: 05-2006
| Gee Ryan that's a bit thirsty !! I use 10L/100Km on a trip at a cruising speed of around 120KPH and somewhere between 11.6L/100Km and 12.8L/100Km around town depending on how hard I am on the pedal , gas it up hard and it will suck it down . Even my wife noticed that it was far more "crisper" after I fitted the Apexi filter . Have a look at the filtering ability of the following , don't know about Trust but I would be checking it out !!
Ryan Posselt
Posts: 42 Reg: 08-2006
| Well this is what my filter looks like Rich... Are you sure your doing your maths right? because i get 600kms for about 80L of fuel (98 octane) and you said your getting 550kms? hmmm well if your getting in the 10s thats brilliant! And i may have to consider the upgrade
Ryan Posselt
Posts: 43 Reg: 08-2006
| P.S filled up today and got 13.66l/100km thats 73.9L for 543KMS |
Rob Andreacchio
Moderator Victoria Supercharged VT Calais & 1991 JZZ30
Posts: 1982 Reg: 01-2005
| I get around 600km to a tank with 98 ron fuel driving the car like an a$$hole! have a TRD panel filter in mine with the front of the airbox cut open... |
Brendan Horton
Tinkerer NSW 1UZFE
Posts: 38 Reg: 12-2005
| Im getting around 500km to a tank mostly all city driving and thats light footed driving!!! Is mine rather thirsty? What should I be looking at to see if it is drinking more then she should? |
Blair Walsh
Posts: 48 Reg: 08-2005
| Mine averages about 15L to the 100 and thats driving conservatively, its the c-f model so maybe the extra weight has an effect on fuel efficiency |
Rich O'neil
Posts: 47 Reg: 05-2006
| My last tankful was 1.9l/100K's , but I have noticed the milage getting worse lately , I'm not surprised due for as I'm overdue for plugs leads , rotors and caps . |
Adam Sanders
TryHard NSW V8
Posts: 248 Reg: 07-2005
| My celsior used to get 500 or 515 max per tank. Now in the 1998 ls400 I get 600 easy. I think the engines are old and out of tune maybe |
Posts: 5044 Reg: 05-2005
| Also the VVTi makes a big difference to economy. |
Brendan Horton
Tinkerer NSW 1UZFE
Posts: 46 Reg: 12-2005
| How big are the tanks in the C-F? |
Ryan Posselt
Posts: 49 Reg: 08-2006
| 85L |
Adam Kotlarski
Tinkerer SA Celsior V8
Posts: 26 Reg: 08-2006
| Rich, did you ever end up making up a jig for that custom adaptor you made? Just wondering as i've been considering putting in a pod filter, purely because the stock toyota filter is a rip off and i'm not interested in continually forking out the dollars for it. Rob, i envy your car. After filling up my tank the other week, it got down to half a tank 150ks later.... and you all think your cars are thirsty, and to top it off i do like to give it a bit pretty often, but i don't thrash it 24/7 so the consumption does concern me a little. Blair, mines a CF too so i think we may be onto something here |
Dimitrios Amerikanos
Tinkerer TAS Supra TT and Celsior
Posts: 20 Reg: 03-2006
| Ha you think that's bad, i get about 250km out of a full tank and that's driving it like miss daisy. I think the problem is my MAF sensor but i'm not 100% sure. |
Ryan Posselt
TryHard NSW Celsior V8
Posts: 236 Reg: 08-2006
| just a hint kids..... driving in the city mashes your fuel consumption, my average consumption went from 600+ / tank in newcastle to -400 in sydney |
Matt Ramsay
Tinkerer sa celsior v8
Posts: 39 Reg: 01-2007
| im getting 450-500 around town. not in overdrive. but thats not totally running the tank dry. should never do that anyway and pick the up from in the bottom of the tank |
Sam Avery
Tinkerer south australia celsior v8
Posts: 68 Reg: 10-2006
| hey rich, did you ever end up getting that jig done? i would like to put an a/m filter on mine. |
Ryan Seddon
Tinkerer Victoria R31 Skyline
Posts: 7 Reg: 05-2007
| Hey is the adaptor available to purchase from you as I would like to fit and apexi filter. What apexi filter do you have is it just a universal one with your adapter? |
Goo Roo New Zealand Celsior UCF11 V8
Posts: 1391 Reg: 11-2005
| Yeah Rich, Is it possible to purchase brackets like these as I may look into doing a similar intake setup than using the stock expensive filters? |
Rich O'neil
TryHard Queensland 90 Celsior
Posts: 149 Reg: 05-2006
| See Big Brakes Update for more info . |
