  Soarer Central * Celsior Chat * Celsior Performance Previous Previous    Next Next
Celsior UCF11 V8
Thursday, September 13, 2007 - 09:04 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive found when I first had my celsior it was good for a 100km/h sprint in just over 8 seconds. Which was pretty good.
Now with replacing all the key electrical ignition gear, the BFI and a few other common servicing items its quite capable of 100km/h sprints in 7.7-7.9s which I find is pretty rather decent considering its one of the more heavier models and pretty much standard. It would be amazing to see how a full exhaust, ecu and decent tyres would improve the acceleration, I'm sure low 7's would be no trouble if not high 6's... :-)
How are other members celsiors/LS400's performing?
Juan Hutinel
S.A.
Soarer JZZ30 GT-TL
Reg: 07-2007
Thursday, September 13, 2007 - 09:16 pm, by:  Juan Hutinel (Juanted) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What does a BFI on an Celsior/LS400 look like??
Celsior
Thursday, September 13, 2007 - 10:12 pm, by:  Greg Nikitiuk (Jestr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Beck wrote on Thursday, September 13, 2007 - 09:04 pm:
you'll get it low 7...to go under 7 you have switch TRC off
Celsior UCF11 V8
Friday, September 14, 2007 - 05:13 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Juan Hutinel wrote on Thursday, September 13, 2007 - 09:16 pm:
Since the intake is circular on the Celsior is kinda like a big circle cutout pretty much, But you dont see it at all as theres a cover over it. Works really well and sounds brilliant, Much more aggressive sounding than my v8 soarers one was...
Friday, September 14, 2007 - 06:31 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sub 8 seconds is very good for such a large saloon. Sounds like it'd see off many older model XR Falcons and SS Commos no problems!
Kevin Cameron
Celsior
Reg: 02-2007
Friday, September 14, 2007 - 07:30 am, by:  Kevin Cameron (Kevin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike,
The prior owner of my car did the cutout of the air filter lid and it has the sound you talk about. Have you done something so it picks up cold air only. If so, can you please post up a photo. I think mine only gets hot air and it pings most of the time. I have noticed on cold nights she doesn't ping, so I gather this is due to the hot air only. Well that's what I am hoping for as I have organised to get a new air filter lid.
Kev
Rich O'neil
90 Celsior
Reg: 05-2006
Friday, September 14, 2007 - 07:44 am, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kev go to Full Strength Planet soarer and look up the BFI section , all the info is there , it shows a Soarer but the same applies to the Celsior .
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8
Saturday, September 15, 2007 - 02:29 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LSD will do more than bigger tyres.
Simon Martin
Celsoir UCF11
Reg: 06-2007
Thursday, September 20, 2007 - 10:21 am, by:  Simon Martin (Commander) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ya speaking of, how much to buy a Supra LSD (which one), (that bolts in) and how easy to fit it? (would it need to be done my a mechanic)?
