Tuesday, January 01, 2008 - 09:24 am, by: Rich O'neil(Kiwiinaus)
Last Friday had a bit of time to fit above bush's , I already knew I had sideways movement of the rack [ about 3 mm ] and you could see the sideways wear marks in the old bushes !! I knew that new front sway bar bush's would improve things but it is a huge improvement !! Same as with the rack , no slop at all . Can't wait till I get the new lower control arm bush's and radius rod bush's in as well !! The new rack bush's are a little different to the originals , they had a fibre type matt where the bar runs and the split was in a different place . I have even taken the suspension controller off the hard setting and it's still a little stiffer than it was . I think it's even better than when I first had the car at 108,000 K's Very pleased .
