Wednesday, July 09, 2008 - 05:26 pm, by: David Barnes(Toyota_celsior)
Gday gents,
I did a search on the issue but could only find issues relating to fuel guage.
My celsior has always had a problem with the temp guage, It reads halfway when the car is dead cold and works its way up to just before the red when warmed up. The car is definetly not running as hot as it suggests. But I would still like to have this issue fixed.
My assumption is that it is due to bad capacitors in the dash cluster circuit board but wouldnt have a clue which ones.
Anyone ever had/seen this problem and know of a fix???
Thursday, July 10, 2008 - 07:32 am, by: Rich O'neil(Kiwiinaus)
I heard of this a couple of times , replacing the temp sender would be the best place to start , not too hard too do and cheap . I always keep at least one temp sender on the shelf , while you are at it you should do the temp sender for the ECU as well .
