Rich O'neil
TryHard Queensland 90 Celsior
Posts: 340 Reg: 05-2006
| had my shifter out completely last night on a look and see mission . Haven't been able to get the later model handle with the O/D button on the side...it irritates me , my Cressida had it on the side , my V6 Camry had the O/D button on the side but not my Celsior !! So I now have the first of the gated shifters complete , it's not a direct bolt swap over but won't be too difficult , there's nothing on the gated unit that's not already on the original shifter , even the wiring won't be too difficult as even though the colours don't match with them side by side you know what goes where . Most important thing is the connection to the G/Box is the same . We will see how it goes tomorrow , will be at it til it's done . |
Steve Eardley
Tinkerer Derbyshire UK celsior
Posts: 29 Reg: 10-2007
| Could you please take some pictures as you go along? |
Andrew Smith
Tinkerer vic v8
Posts: 95 Reg: 03-2007
| this has been done in japan. if i get time ill scan the pics and upload it |
Moderator New Zealand Mercedes Benz SLK230 Kompressor
Posts: 6811 Reg: 05-2005
| I've got the pic tutorial on the gated shifter installation, but it's for doing it to a Soarer..........a LOT more faffing around than a Celsior/LS400. |
Posts: 6812 Reg: 05-2005
| This is the shifter parts pic from the 10/94 - 2000 Celsior/LS400 EPC. Lotsa little bits n' pieces. Rich, if ya need any part number help just drop us an email: bagnall@xtra.co.nz 10/94 - 7/97.
I can do a close up on any part of these pics if you need it.
Posts: 6813 Reg: 05-2005
| And the 7/97 - 2000 pic.
Rich O'neil
Posts: 344 Reg: 05-2006
| Shifter is in !! Haven't finished the trim yet and I've done it a bit different to the guy on Club Lexus , I haven't chopped apart the gated unit , it sits a bit higher than the standard unit and I will play with the trim instead . The wiring was a bit tricky due to the extra switch stopping you going from neutral to reverse , but I now have it working correctly and I will do a diagram and take some pics . Being able to work the O/D by just pushing sidewards is great , it's less effort to go from Park to reverse but more effort to go from Drive to park when you stop and leave the car , like it a lot and it also makes it look a bit more modern . Don it's only the very first of the gated shifters that will work easily as as soon as it went to the 5 Spd box you have an extra position IE: D , D4 , D3 , D2 , L where as the one I have is D , D3 , D2 , L just like the original and as I fitted the thing as a whole didn't need to break it down . But thanks for the diagram anyway I have filed it way just in case !!. I don't suppose you can get you hands on Australian lexus parts prices can you ? |
Posts: 6816 Reg: 05-2005
| No, sorry Rich, no access to that sort of info. |
Stuart Smith
TryHard NEW SOUTH WALES SC400 V8 GT LIMITED
Posts: 105 Reg: 06-2008
| Don, Would it be possible for you to post or email a close-up pic. of the shifter mechanism for the `91 V8 Soarer, I think the pivot bushes are crook/missing in mine. |
Posts: 6859 Reg: 05-2005
| No worries Stuart. I replaced mine about 3 years ago........1 was super worn, and the other was a tad floppy. If I remember they were about $6(NZD) for the two of em. Not hugely hard to do, just fiddly.......took about an hour from go to woa
Bob O'Brien
Newbie Vic. V8
Posts: 4 Reg: 04-2007
| Don Where do these images come from? Is this software anyone can get a hold of? |
Posts: 6862 Reg: 05-2005
| Hi Bob, The images are from the Toyota EPC (Electronic Parts Catalogue).
Stuart Smith
Posts: 115 Reg: 06-2008
| Thank Ewe Don , You really do have the goods. Thanks also for the heads-up on the Toyota EPC source. Hey, If Ass is an Americanism, Is Ewe a Kiwizdom? |
Bob O'Brien
Newbie Vic. V8
Posts: 5 Reg: 04-2007
| Thanks for the info Don, much appreciated |
Posts: 6868 Reg: 05-2005
Stuart Smith wrote on Sunday, August 03, 2008 - 05:41 pm:Is Ewe a Kiwizdom?
As in Ewes fulla's..............Bucket if I know (he said sheepishly) Er....... Moooooo! Oar knot, as the case may bee) ps: I thought an Ass was what the late J.C. cruised around Jerusalem on till he got his divine mitts on a 38 Buick Straight 8 |
David Barnes
Tinkerer Qld Celsior V8
Posts: 48 Reg: 06-2008
| Woah these gated shifters aint cheap, Saw one the same as Rich as installed on yahoo japan for $400. I was thinking of doing this untill i saw the price tag. Nice job tho Rich, got any pics mate? |
David Barnes
Posts: 49 Reg: 06-2008
| btw guys you can download the Toyota EPC off the internet. Here is a link to the torret on mini nova http://www.mininova.org/tor/1154565 |
Stuart Smith
TryHard NEW SOUTH WALES SC400 V8 GT LIMITED Proper Prior Preparation Prevents Piss Poor Performance
Posts: 170 Reg: 06-2008
Don Bagnall wrote on Sunday, August 03, 2008 - 12:18 pm:Not hugely hard to do, just fiddly.......took about an hour from go to woa
Fibber.....
Stuart Smith
Posts: 171 Reg: 06-2008
| The shifter bushes (Part # 90385-11003) are a $4.00 purchase for the pair, and a stocked item, must be common to other Toyota models. While I have it apart I will modify the shifter to take a more conventional gear knob, and lower it. The lock out function will be done by pushing down on the knob for park reverse and low. Overdrive will be via a switch in the TRC hole operating a latching relay.
Posts: 6938 Reg: 05-2005
Stuart Smith wrote on Sunday, August 24, 2008 - 06:55 pm:Fibber.....
Jeez!, ya sure ya pulled enough of the car to bits |
Stuart Smith
Posts: 177 Reg: 06-2008
Don Bagnall wrote on Monday, August 25, 2008 - 06:01 pm:Jeez!, ya sure ya pulled enough of the car to bits
Seemed like a good idea at the time. BTW, I finished the shifter mod.(except the relay for O/D function). I am very happy with how it worked out, much easier to operate.
Posts: 6940 Reg: 05-2005
| Looks damn fine Stuart...........Actually classier than the original......Noice! |
Goo Roo New Zealand Soarer Limited UZZ31 & Soarer 3.0GT JZZ31
Posts: 2388 Reg: 11-2005
| Hmmm, looks like good work! But I don't think I could get used to something like that, I prefer my factory spruce shifter over any other shifter, other than a TRD shifter for a W58!
Stuart Smith
Posts: 180 Reg: 06-2008
Mike Beck wrote on Tuesday, August 26, 2008 - 03:25 pm: I don't think I could get used to something like that
Mike, That was the reason that I changed it, I kept pushing the O/D button instead of the lock-out button, driven too many miles in old American cars I guess. Plus I wanted to lower it. |
Posts: 2391 Reg: 11-2005
| Ah yes, I see it from your perspective. With me since I've became interested in the Soarers, I always liked the automatic shifter as it was different from 99% of other Japanese cars at the time which where like a fist sticking up out of the dash, nasty! I do love the gated shifters like the later model Celsior have though. Very euro looking.... |
