  Soarer Central * Celsior Chat * Need new alternator! Previous Previous    Next Next
Daniel Ames
Reg: 09-2008
Sunday, September 28, 2008 - 05:52 pm, by:  Daniel Ames (Dan0) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anyone know of where to get a refurbed or new alternator for my poor baby? i found one on eBay.com for USD$125 plus P+H but id rather find one locally if anyone can help that would be great!!
Andrew Smith
vic
v8
Sunday, September 28, 2008 - 06:11 pm, by:  Andrew Smith (Bt1323) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
get the one from ebay champ it will be cheaper in the long run
Daniel Ames
Reg: 09-2008
Sunday, September 28, 2008 - 06:15 pm, by:  Daniel Ames (Dan0) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks matey will this one work on my 89 celsior, surely the alternator for a ls400 '90 will do???
alternator
http://cgi.ebay.com/ebaymotors/New-Alternator-Lexus-LS400-SC400-1990-1994_W0QQcmdZViewItemQQ_trksidZ p1638Q2em122QQcategoryZ33573QQihZ001QQitemZ110293670246QQrdZ1QQsspagenameZWD2V
Andrew Smith
vic
v8
Monday, September 29, 2008 - 06:39 am, by:  Andrew Smith (Bt1323) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes i would certainly think so i don't the ls400 came out in 89 prob shoot the seller a question.
David Barnes
Celsior V8
Reg: 06-2008
Monday, September 29, 2008 - 10:18 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It will work,
Celsiors came out in Japan in 1989, and introduced to the rest of the world as the LS400's in 1990.
David Barnes
Celsior V8
Reg: 06-2008
Monday, September 29, 2008 - 10:22 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh btw, definetly be able to get one cheaper then that.
If I was you id be getting a reco one on an exchange basis.
Hugh Cansdell
V8 Celsior
Reg: 02-2007
Monday, September 29, 2008 - 01:11 pm, by:  Hugh Cansdell (Whooby) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They're not all the same, I made the mistake of buying a soarer alternator. Didn't have enough amps.
I'm pretty sure that the LS400 alternator didn't have as much 'kick' as a CF-Spec Celsior.
They physically look the same and it will bolt on.
Just a word of warning from experience, buy the right one.
Andrew Smith
vic
v8
Monday, September 29, 2008 - 04:14 pm, by:  Andrew Smith (Bt1323) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there is one on ebay with 90amps and 110 amps go the one with more amps
Mike Bomhoff
Manitoba
Celsior C-F
Reg: 11-2007
Wednesday, October 01, 2008 - 07:19 am, by:  Mike Bomhoff (Cleaner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Why not get the original rebuilt? I had mine done and for $100 I have what looks to be a brand new alternator with warranty. It took a few hours to have it rebuilt and it was ready to go back in.
Rich O'neil
90 Celsior
Reg: 05-2006
Wednesday, October 01, 2008 - 08:34 am, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel I have a spare that I replaced with a new unit in my car , great for a rebuild and swap over , then you can do the same for some one else with the one you pull out .
