Monday, February 16, 2009 - 06:55 am, by: Brendan Horton(Vip)
Hey guys, I am currently looking at a new set of shoes for my Celsior... I am not sure they would fit though, I used to have 19x9 on the rear and they only fit up in the guard by 2mm clearance, not sure what the offsets were for it, but now I am looking at REAR 19X10 +38 FRONT 19X9 +38 PCD
Monday, February 16, 2009 - 04:49 pm, by: Andrew Smith(Bt1323)
+38 will fit you wont need to camber it much, and depends what height you ride at also.stretched tires no stretched tires, there is alot of factors as aaron mentioned
Wednesday, February 18, 2009 - 08:17 pm, by: Ryan Posselt(Yakusaryan)
Hi All, With just the rims at the above size and any choice of tyre - stretched or other wise, would it be hard to make these fit? for example would a mild guard roll work? how much camber change would be required? has anyone else got rims this size on their celsior?
Thursday, February 19, 2009 - 05:19 pm, by: Rich O'neil(Kiwiinaus)
That's the reason I like 18" rims as then you can easily get a 9.5" or 10" wide rim on the back with a 275/35/18 on it and still have no clearance problems , currently I have 8.5 on the front and 9.5 on the back both plus 40 with 235/40/18's on the front and 265/35/18's on the back and they clear with no probs . I believe that if you go to a 19" rim on the back you have to come down to a 245 unless you roll the guards , not easy when they are double skinned . The extra 20 mm of width suits the car as well , nothing like big fat feet !!
