  Soarer Central * Celsior Chat * Celsior Folding Mirrors Previous Previous    Next Next
Steve Eardley
Derbyshire UK
celsior
Reg: 10-2007
Thursday, March 05, 2009 - 05:54 am, by:  Steve Eardley (Steve2006) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Everyone,
My Celsior is still running fine apart from the intermittant starter motor problem for which I have the rebuild kit and all the gaskets so just got to get it done.
Does anyone have any info on the power folding mirrors preferably a circuit diagram I have the stock LS info but they are not fitted on this model.
Many thanks,
Steve
David Barnes
Celsior V8
Reg: 06-2008
Thursday, March 05, 2009 - 08:53 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmm no nothing like that,
But its not hard to work out, its just 12volts and a switch :-)
So I assume you got yourself some folding mirrors, Did you also get your self the dash switch for it?
Folding mirrors are kinda useless anyway I think haha.
I have been wanting to wire mine up into the switch that detects if there is a key in the ignition so they automatically close when I turn the car off and take the key out :-) (I need some kind of special relay to do it yet, as the ignition switch is constant open or closed circuit and the mirrors don't work like that.
I hope that made sense :-)
Check out clublexus.com alot more traffic on that site then this :-)
Bob O'Brien
Vic.
2 x '90 Celsior V8
Reg: 04-2007
Thursday, March 05, 2009 - 09:36 am, by:  Bob O'Brien (Barcode) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David
Here is a very good article on relays that should help.
http://autospeed.com/cms/A_110901/article.html
Bob
Steve Eardley
Derbyshire UK
celsior
Reg: 10-2007
Friday, March 06, 2009 - 06:44 am, by:  Steve Eardley (Steve2006) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi,
No I already have a Celsior which has the folding mirrors as standard but I am trying to help a guy in N.Y. who is trying to retro fit some to an LS and I thought there seems to be more Celsiors in N.Z. and perhaps the infomation about the mirrors.
Is it possible to obtain the Celsior workshop manuals anywhere?
Cheers,
Steve
David Barnes
Celsior V8
Reg: 06-2008
Saturday, March 07, 2009 - 10:34 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh thanks Bob, I will have a read :-)
Steve, This is Australian Based Forum :-) Any Celsior workshop manuals would be Japanese. Might be able to use to wiring diagrams tho,
Its just 12volts and a switch :-) Im sure he will work it out.
