  Soarer Central * Celsior Chat * Extractors for Celsior/LS-400 Previous Previous    Next Next
Fran Valdivia
Wollongong NSW
Soarer TT & V8 Limited
Reg: 01-2007
Sunday, June 14, 2009 - 06:55 pm, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was hoping to see if anyone knew if extractors are/were available for the Celsior/LS-400?
Where from, and who?
Or, if anyone knew who could modify a set of Soarer extractors to fit the Celsior?
Fran Valdivia
Wollongong NSW
Soarer V8 Limited & Cesior
Reg: 01-2007
Friday, July 03, 2009 - 07:55 pm, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, so Ive worked out that no one knows where to get extractors for their Celsior.
Can anyone tell me if they have a set fitted?
Then I can continue the hunt for someone that may be able to make.
All Ive worked out thus far is that the left extractor from the V8 Soarer fits, and the drivers side needs to be heavily modified to fit.
Fran Valdivia
Wollongong NSW
Reg: 01-2007
Monday, July 06, 2009 - 10:43 am, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone have extractors fitted to their Celsior?
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8
Monday, July 06, 2009 - 11:25 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can always get a set custom made.
Or find someone who has a Celsior front cut (with the motor still in) and obtain a set of Soarer extractors to test fit, see exactly how much has been modified.
There have been a few people on Lextreme with Celsior's who have fitted extractors, however, I can't remember if they have been LHD or RHD, and from memory they have all had them custom built (either themselves or by a shop).
All that said, extractors would be one of the last things I'd do to a Celsior. The stock headers flow the best of the stock types.
I've seen people pull the same rwkw with celsior headers as I have seen with extractors. However, I don't know how the rest of the rpm compares.
For the price of a custom set of extractors you can be halfway to an M90 s/c kit. And I know what I'd chose between extractors or 4psi...
Tristan Chun Tie
Celsior
Reg: 07-2009
Tuesday, July 07, 2009 - 10:00 am, by:  Tristan Chun Tie (Chunners) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This website lists a set of headers for the 1uzfe engine but doesn't say which vehicle they will fit. However, they do supply a dimensions diagram. Might be worth giving them a buzz to find out if they would fit.
http://www.castleauto.com.au/hs_dbase/format_search.php?Y2hfaGVhZGVycy5pbmkrYWxsc2VhcmNo
Fran Valdivia
Wollongong NSW
Reg: 01-2007
Tuesday, July 07, 2009 - 08:14 pm, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew Ferres wrote on Monday, July 06, 2009 - 11:25 am:
So true Andrew.
Rang a mob in Sydney today, and they casually said $2500, just for the extractors!
And saw a mate that does exhausts for a living, and at mates rates its $1500, then have to fit the system behind it.
It just feels like a slug off the mark, but once the car is moving you can feel it wants to let loose.
That's why I was under the impression that extractors would help.
It has a sports system, I just wanted the performance to match the sound
Thanks for the link Tristan.
Will take a look
Andrew Ferres
Tuesday, July 07, 2009 - 08:23 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Generally speaking, extractors reduce low end torque, so they'll make the car feel slower to take off.
A well designed set of extractors will make this almost negliable though.
If you want the car to feel quicker off the line, then fit a 4.1:1 diff with LSD.
You'll use more fuel cruising, but it will feel much quicker.
Rich O'neil
90 Celsior
Reg: 05-2006
Tuesday, July 07, 2009 - 09:19 pm, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have been looking at getting a jig made up for Extractors for the Cel by one of the best custom guys here in Brisbane .
I would have to order 10 sets to make it worth his while , they would be 4 into 2 into 1 units and nearly equal length designed specifically for the Celsior , this would preserve the bottom end and give you increased mid range , around 25 HP more ,the engine would also rev out a bit quicker and be a bit more economical in normal use .
Cost per set would be about $1100.00 .
I would need ten people to give deposits to this guy before I hit the go button .
I have seen a fair bit of his work and he is a pro.
Have a look at his site.
http://www.cesracing.com.au/
Aaron Mead
Tuesday, September 08, 2009 - 02:22 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew: Where do I find such an LSD for the Celsior?.
Rich: Whats fitting going to be like fro these headers? Looks like a nightmare underneath !!
Andrew Ferres
Tuesday, September 08, 2009 - 11:41 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any diff centre to suit a 'G series 8" diff' will fit (or can be made to fit).
Its something that needs to be done by a diff shop though.
87-92 Supra, most 90s Hilux's (may need machining).
They would be the most common and readily available.
Rich O'neil
90 Celsior
Reg: 05-2006
Wednesday, September 09, 2009 - 04:24 pm, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aaron fitting the headers on would probably be easier than getting the standard manifolds off !!
But I'm just guessing , from others that have done it it's not a complicated job , just a tricky time consuming one !!
Aaron Mead
Wednesday, September 09, 2009 - 05:29 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Andrew and Rich.
In some of the other threads, I have been looking at what is worthwhile and what isnt. My Celsior is a little run down, considered selling it, wouldnt get SFA for it, and having just rented a holden statesmen for 6 days (apparently, thats an UPGRADE from an Aurion?)I really have come to apprieciate how good these 20 year old beasts are, and so Im going to renew all my suspension components first. My bags (baby) are in pretty good nick as far as I can tell, not having a UCF11 with new bags in it on hand to compare with, but the front end is rattly as all hell.
So begins the pocket emptying excercise :-). Headers, blower and other bits can wait for fitting, but it's nice to know they will be available. Im in for a set when they are ready, will leave in the garage for the time being.
David Barnes
Celsior V8
Reg: 06-2008
Wednesday, September 09, 2009 - 07:24 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Technically they arnt extractors, But these headers are still better then stock.
http://www.l-tunedparts.com/product/?id=2103
Suprized no one said anything about them yet.
Personally, save you money and just supercharge it, best bang for buck, extractors are a real pain to fit aswell.
Andrew Ferres
Wednesday, September 09, 2009 - 08:20 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They are designed to suit the LHD LS400, there is no guarantee that they'll fit the RHD models.
Unless someone has already tried?
And if you supercharge it, you NEED extractors.
Rich O'neil
90 Celsior
Reg: 05-2006
Wednesday, September 09, 2009 - 08:32 pm, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes and they are also a four into 1 which is not ideal for a Cel , a set of Tri Y's is what's needed .
Aaron Mead
Thursday, September 10, 2009 - 12:46 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The S&S headers have been mentioned a few times on this site, and of course a lot on Lextreme and clublexus sites.
The biggest issue was wether they would suit RHD models; I never got to follow up a confirmation on that. I dont know what they would foul on, perhaps steering possibly, but you dont know until you try I guess....
Guinea pig anyone?
David Barnes
Celsior V8
Reg: 06-2008
Thursday, September 10, 2009 - 02:37 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You don't NEED extractors if your going to supercharge, The stock headers on the Celsior will support a supercharger no problem. It will just create more power with a set.
Mate of mine had over 200rwkw's with stock headers in his Celsior.
And the debate of tri-y and 4 into 1, is a general rule but its not set in concrete, majority of the extractors you see for the ls1's are 4 into 1 and have been known to make more power with no compromise on low down torque then the tri-y design.
In regard to S&S headers fitting rhd ls400/celsiors, i have seen a celsior for sale in the past with a set of s&s's fitted, couldn't tell you if they were modded to fit tho, but it has been done.
Aaron Mead
Rating:
Votes: 1 (Vote!)
Sunday, September 13, 2009 - 07:08 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
True.
you dont NEED an LSD with a blower either, but I aint dropping no faggy single spinner wheelies in my blown 1UZ :-)
James Walker
v8
Reg: 12-2008
Monday, November 30, 2009 - 05:20 pm, by:  James Walker (Jimmywalker) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any one had any luck with a LSD ?
Aaron Mead
Monday, November 30, 2009 - 05:36 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im still looking mate. I think I found something on the japanese Cusco site for a Cusco Hybrid series LSD. part number HBD 192A. Its all in japlish though and theres some footnotes but because its in PDF i cant cut and paste into babel.
http://www.cusco.co.jp/products/2009webcatalog/index.html#159
Aaron Mead
Monday, November 30, 2009 - 05:37 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Theres a bit of a write up on lextreme about adding a supra carrier and lsd centre. It involves a lot of work though, i.e. drilling the subframe, welding a nut to it to allow a four point mounted diff (i.e. supra) to attach to the LS400 subframe.
