  Soarer Central * Celsior Chat * 1UZFE ignition coil needed. Previous Previous    Next Next
David Barnes
Celsior V8
Reg: 06-2008
Thursday, July 02, 2009 - 09:47 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi :-)
My Celsior is running on 4cylinders, Nutted it down to the coil (the one thats to the left of the Idle control valve on top of the engine, infront of the intake manifold)
Does anyone know where I can find one??
Is it just a generic Toyota Part or 1UZ only.
Andrew Smith
vic
v8
Thursday, July 02, 2009 - 10:23 am, by:  Andrew Smith (Bt1323) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
HOW ABOUT WITH THE GUY WHO WROTE OFF HIS CAR
David Barnes
Celsior V8
Reg: 06-2008
Thursday, July 02, 2009 - 11:13 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I hit him up but was a lil bit pricey for an old ignition coil, plus my celsior has parked in my work ute and need to get it out asap. Ryan wont be up for 2 weeks. I was hoping that it was a generic toyota part and I could grab one from a corolla or something. Ignition coils are all the same basicly, just depends on the conections.
Ryan Posselt
Celsior V8
Reg: 08-2006
Thursday, July 02, 2009 - 11:21 am, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
happy to negotiate price if you need it that bad Someone suggest what one is worth!
Paul Drane
Thursday, July 02, 2009 - 01:06 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can buy new generic coils from places like Bursons for around 90 to 100 dollars, I think new genuine are about 200 or so.
Not saying yours is no good Ryan but you never know how much life it has left in it.
Rich O'neil
90 Celsior
Reg: 05-2006
Thursday, July 02, 2009 - 01:50 pm, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave I have a good coil you can have for $50.00 plus freight .
David Barnes
Celsior V8
Reg: 06-2008
Thursday, July 02, 2009 - 01:56 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rich my friend :-)
I think that may have to be the way to go, I will find out forsure this afternoon as my mate is bringing his soarer around so I can try his coil pack.
Thursday, July 02, 2009 - 02:49 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check Repco, Supercheap etc as coil packs for the V8 are available, possibly as low as $75.00
Personally I wouldn't bother saving a handful of dollars to buy a part that won't have a decent lifetime left in it.
David Barnes
Celsior V8
Reg: 06-2008
Thursday, July 02, 2009 - 10:43 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the tips guys
My mate brang his 1uz soarer around this afternoon and I tried his coil pack, still running on 4 cylinders, even to confirm it, put my coil pack in his car and works fine.
I run out of sunlight before I could do more seaching. I know the other coil pack is fine aswell I put the timing light on its lead that runs to the right hand dizzy (looking at the engine). I will have to put a timing light on the one I thought was crook, I didnt test it at the time because I knew the other one was working and only being 2 I just assumed.
So what else is left?
I was thinking that maybe the coil on the top of the engine isnt getting the signal to fire (connection seems clean and firm so im doubtful on that)
Other option is the lead that runs from the coil to the dizzy is dead.
Or the lefthand dizzy is playing up (the problem did happen after running the engine to redline in 1st gear), is possile the rotor button has somehow snagged and just spinning on its shaft?
Now this leads me to another problem, How to inspect the distribtors.
Last time I changed my plugs I wanted to check them out but I couldnt work out how to remove the lower black plastic casing (timing belt cover)
Does it just unbolt, from memory I remember seeing plasic plug looking things.
Is there a trick to the removal?
If anyone has any advice or suggestion to my above answers it would be greatly appreciated.
Regards,
Dave
Rich O'neil
90 Celsior
Reg: 05-2006
Friday, July 03, 2009 - 06:02 pm, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Where about's in Brisbane are you ?
Bring your car over to me and I'll show you how to do it , I even have some spare caps and rotors as a back up or if you are not too far away I'll come to you .
Give me a call .0400613122
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8
Monday, July 06, 2009 - 11:28 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Swap the plugs over on your ignitors.
If the 'dead' one swap to the other side, then the ignitor is the problem.
If not, then its either a coil lead, the dizzy, or the rotor (since you've ruled out the coil)
David Barnes
Celsior V8
Reg: 06-2008
Monday, July 06, 2009 - 03:33 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got a test light, I will be able to determain where the spark is lost. But my main issue is working out how to remove the timing cover from the dizzy, top half is easy as pie, but does it just unbolt or is there a trick. If someone can give me the heads up on if it just unbolts, then I will persist with it as maybe im not trying hard enough, but as a general rule if someone doesnt come off easy there is normally a trick to it, Just wondering if someone could point me in the right direction,
Rich, Not able to bring the celsior down to kingston im affraid as she barly runs to move it out of the drive way, anything more then idle and it just pops and backfires. My father drives a low loader (trailer used to moving large earth moving equipment) So normally transporting a car is no issue but there is no way the celsior would make it up the ramps on the trailer running on only 4pots.
Im certain its the left hand dizzy (looking at the car) I just dont know how to remove the casing to inspect it.
I thought it would be in the instructions for replacing the timing belt but they dont even explain it or show a picture of how its done, so its gotta be simple. Im just buggered if I can work it out, and I dont want to force and break anything,
If anyone knows. Please give me some advice if shes a just a simple bolt off job. or there is a trick. if there is a trick, is it possible to explain or take a photo to show me.
Thanks a lot guys.
Andrew Ferres
Monday, July 06, 2009 - 04:11 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Driving the car up a ramp on 4cyls should not be an issue.
I've had to limp mine home a couple of km's a few times on 4cyls. Sure its slow and has no power, but it has enough to get the car up to 60kph.
Unplug the 4 respective injectors if you want to stop the backfiring.
As far as removing the cover is concerned, yes, its just bolts (no clips). Bit of a headache to get the cam sensor wire free, but do able.
I just can't remember if anything else needs to come off (like the tensioner pulley). I can't remember the other inwhich its done.
