  Soarer Central * Celsior Chat * Ls400 Air conditioning compressor (1990) Previous Previous    Next Next
Mark Tierney
Soarer GTT & Celsior
Monday, August 10, 2009 - 02:26 pm, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Let the maintenance update begin: 1) air conditioning
For the last few months I've had the crazy squeal coming from my air conditioning compressor on the Celsior. When investigating in Sydney the refurbishment/replacement job was going to cost somewhere between $1000 & $1500 to fix. I wasn't impressed.
Finally I found a link on EBay that seemed almost too good to be true. Reconditioned air con compressors for the LS400 for US$250 with clutch. They even had a best offer option, of which I made an offer of US$230 & they accepted. Shipping was US$91.00, so a total of US$321 (A$382.00 - about $400 - 500 cheaper that I could get it done locally).
The re-gas & new valve was $130 and the labour was about $340.
All up fitted & regassed was $850. If I had have fitted it myself, it would have been a $500 job.
It has been in for a couple of months now & is running perfectly.
I know there are a few of you guys experiencing the same issue of air con, so I thought I'd post the link...
http://cgi.ebay.com/ebaymotors/90-97-LEXUS-LS400-LS-400-AUTO-AIR-AC-A-C-COMPRESSOR_W0QQitemZ35016236 7204QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item51874db2e4&_trksid=p3911.c0.m14
It arrived about a week after purchase and I'm very happy with the result.
Ryan Posselt
Celsior V8
Reg: 08-2006
Monday, August 10, 2009 - 03:15 pm, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not a bad option for you Fran :-)
Fran Valdivia
Wollongong NSW
Soarer V8 Limited & Celsior
Reg: 01-2007
Monday, August 10, 2009 - 05:19 pm, by:  Fran Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Mark,
got the email and have bookmarked the link
Rich O'neil
90 Celsior
Reg: 05-2006
Monday, August 10, 2009 - 07:34 pm, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This might be a better option than one I was considering , later model low mileage units can be had quite cheaply from Japan , however the freight due to the weight [how about that for being a poet !!] puts them around the $300.00 mark in my hands .
Will have to do some more research .
Mark Tierney
Tuesday, August 11, 2009 - 08:35 am, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They come with the dryer unit as well. Its advisable to replace this with the compressor.
Tristan Chun Tie
Celsior
Reg: 07-2009
Tuesday, August 11, 2009 - 10:14 am, by:  Tristan Chun Tie (Chunners) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
You can buy replacement parts in australia from the company below.
http://www.nippon.com.au/profile.htm
I've contacted andrew and was quoted the following for my 1990 celsior:
-Compressor TA2302. I can supply this compressor as a remanufactured item only. Cost is $475.00 + GST
-Receiver Drier FD1005. Cost $20 + GST
-Evaporator. No part number. Cost $400 + GST. I will need 2 days to obtain this part.
-Condenser. Not available as an aftermarket part. Genuine only item.
Alternatively here is another site if you want to but from oversea from ebay
http://www.elitelexusparts.com/lexus-ls400-Air-Conditioning-and-Heat-parts-33542.htm
Hope this info can help somebody else
