  Soarer Central * Celsior Chat * Cluster issues - Displaced needles? Previous Previous    Next Next
Scott Faulks
UFC11
Reg: 09-2008
Monday, September 21, 2009 - 08:42 pm, by:  Scott Faulks (Faulksy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have issues with my instrument cluster on my Celsior. I bought the car and neither the temp, fuel, or tacho register correctly.
The fuel gauge only up to just over 3/4 when full
Temp gauge sits 1/4 up once car started and almost sitting 4/5 up when at normal running temp
The tacho sits well below zero and finally gets it boogey on at higher revs and creeps up to one
I believe the needles on the cluster have just come displaced. Anyone know if they just sit on a spline and put back to where they should be
David Barnes
Celsior V8
Reg: 06-2008
Tuesday, September 22, 2009 - 09:53 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, pretty much mate, just push them back to there home position, they will slowly creep up again.
I have covered this in the past on here.
The kinda job you gotta do once a year/2years.
Scott Faulks
UFC11
Reg: 09-2008
Tuesday, September 22, 2009 - 12:51 pm, by:  Scott Faulks (Faulksy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok thanks. just wanted some confirmation that was the issue before starting otherwise I had another cluster here but is in a unknown condition
