  Soarer Central * Celsior Chat * Headlight and engine fan issue Previous Previous    Next Next
James Paton
Celsior V8
Reg: 12-2009
Wednesday, December 16, 2009 - 08:50 am, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey All,
New here, have had my Celsior for over 3 years now. I have a couple of issues which are really annoying me now.
1. Headlight will not turn on, tail lights, brake lights, parkers and high beams all work fine but no low beams. When I try to turn the lights on the high beam dash light will go on. I have tried changing the relay, checking fuses, testing the globes and cant figure it out.
2. Engine fan... it continuously runs and most of the time is running on high so its really loud. If its cold outside it still runs high. I have flushed out the system and replaced coolant with no change. I'm going to change the Coolant Temperature Sensor on the block on the weekend but does anyone else have any ideas?
Thanks!
James
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Tuesday, December 29, 2009 - 07:37 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check the contacts where the cable connects to the globe holder.
The Celsior uses a Hydro fan, there is a control box that should be near the steering column that controls the hydro fan. Maybe you could try use another box but I'd start first with the coolant temp sensor.
James Paton
Celsior V8
Reg: 12-2009
Wednesday, December 30, 2009 - 12:50 pm, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Boris,
I have checked the contacts with a multimeter and they are all good. Im thinking integration relay now.
I have changed the coolant temp sensor now and that didnt make any difference, maybe the sensor on the bottom of the radiator is at fault or maybe another flush is in order.
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Friday, January 01, 2010 - 03:38 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey james there is a integration relay on ebay right now this could help with your head light issue
James Paton
Celsior V8
Reg: 12-2009
Friday, January 01, 2010 - 08:22 pm, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Joshua... I might be the one selling the relay haha. Its the wrong one for my Celsior unfortunately.
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Friday, January 01, 2010 - 10:37 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha thats fair enough mate. good luck on fixing your problem though
Tom Lanyon
Supra MA71 + Celsior C-F V8
Reg: 01-2007
Tuesday, January 05, 2010 - 02:50 pm, by:  Tom Lanyon (Toml) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have the same issue with the hydro fan constantly running fast.
I was told that the temp sensor on the bottom of the radiator is the one that the hydro fan runs from so I am going to attempt to change this first.
James Paton
Celsior V8
Reg: 12-2009
Wednesday, January 06, 2010 - 11:35 am, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah thats what I will be doing soon... Im assuming it means another coolant flush though so Im waiting a little bit just to get the most out of what I have in it haha. BTW that sensor is $140 ish new from Toyota.
James Paton
Celsior V8
Reg: 12-2009
Tuesday, January 12, 2010 - 11:00 am, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any luck Tom? Mine was starting to overheat so I change the thermostat and radiator cap and gave it another flush... unfortunately still the fan issue but it doesnt seem to be overheating now.
I may have a buildup of sludge in my radiator as the previous mechanic mixed green and red.
James Paton
Celsior V8
Reg: 12-2009
Monday, January 18, 2010 - 06:22 am, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just an update...
Fixed my cooling fan issue, my issue was a blocked radiator, then fan was struggling to cool the previous one cause it was so blocked. New radiator and its all good. Now on to the headlight issue.
Matt Shields
Reg: 01-2010
Sunday, April 11, 2010 - 06:56 pm, by:  Matt Shields (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
james, did you get any further with relay issue?
James Paton
Celsior V8
Reg: 12-2009
Monday, April 12, 2010 - 01:09 pm, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Matt... had to replace the integration relay. Ended up getting one from Japan.
