Thursday, January 14, 2010 - 11:15 am, by: Martin Capobianco(Cappakazi)
Hi,
I was wondering if anyone has come across this issue in there cars? The taillight sensor has appeared on the instrument cluster (orange light of a car with lines coming from the rear of it).
It means that there is a voltage drop in the circuit, normally referring to a blown bulb. But i have no blown bulbs, is there anyway to fix this problem i hate looking at this light all of the time.
Thursday, January 14, 2010 - 05:16 pm, by: Rich O'neil(Kiwiinaus)
Been through this myself and it turned out I had missed one , are you sure you haven't missed one of the bulbs ? After all there is a few of them !! Including the two in the high level brake light ?
Friday, January 15, 2010 - 10:01 am, by: Martin Capobianco(Cappakazi)
It might be the Lamp failure module because i've had the car for a year now an never changed any bulbs and the light just came on last week. So therefore it wouldn't be using different bulbs or the configuration because i would have come up earlier. Il check the high level brake lights i know its on but maybe 1 is out. Ill give that a shot first if not its the module. Thanks
Sunday, January 17, 2010 - 07:33 pm, by: Joshua Baldwin(Celsior101)
i have the same problem as well im sick of looking at it lol and would like a solution on how to fix it! i remember changing one of the brake lights to replace a blown one when i was getting a road worthy... where is the module located on the car? and could the fault be from anything else???
