  Soarer Central * Celsior Chat * After market pads for 4 pots Previous Previous    Next Next
Ron Bassett
v8 LTD
Reg: 04-2007
Thursday, February 04, 2010 - 03:35 pm, by:  Ron Bassett (Ron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has anyone part numbers or a resource for good pads for mid 95 Celsior 4 pot brakes???? Tried a search and could not find anything...
Aaron Mead
Thursday, February 04, 2010 - 05:10 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
GDB3226 for the Lucas/TRW.
04465-50070 O.E.M. Toyota.
Lucas/TRW are arguably the best value for money pad you could possibly fit to a large cruiser.
If you are using the pad wear indicators, you may also need some new ones
O.E.M. P/N 47770-50030
Ron Bassett
v8 LTD
Reg: 04-2007
Friday, February 05, 2010 - 08:05 am, by:  Ron Bassett (Ron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Aaron...I don't suppose you would have similar details for after market slotted rotors and OEM details for them????
Aaron Mead
Friday, February 05, 2010 - 12:49 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
GD7207- this is from the EBC parts catalogue: exact same item as RDA7517. SO go to a RDA or EBC reseller and quote that number for 314mm rotors to suit 1995 LS400.
They are a bit fugly though, but look good once the passivation wears off (coupla days):
http://cgi.ebay.com.au/Lexus-LS400-2-0L-10-94-00-Front-Gold-Disc-Rotors_W0QQitemZ200435369318QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item2eaae10566
For DBA resellers , quote p/n 745. Dont think they do slotted though
Other slotted stuff can be bought on eBay (US) for cheap but the freight is a total killer.
Ron Bassett
v8 LTD
Reg: 04-2007
Friday, February 05, 2010 - 02:42 pm, by:  Ron Bassett (Ron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks again Aaron....obviously you have them on your car? What are your impressions?
Aaron Mead
Friday, February 05, 2010 - 03:29 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I actually the plain rotors. I couldn't justify the extra price for the slotted version, espcially with the 'full face' wheels I have.
My four pots came rebuilt from rockauto in the USA, fully loaded with new shims, pins, banjos and new pads too, for $400au.
I went straight to the brake shop and ordered the Lucas pads, having had a lot of good experiences with them on the soarer and the benz.
What can I say, I had rather poor condition 2 pistons before i swapped to four potters, so the change was naturally, out of this world!
But a year later, they still shed speed a lot quicker, easily finding the limits of your tyres.
I did use the RDA dimpled and grooved rotors on the soarer with Supra 4 pots some years ago. No issues, and a massive improvement over the 296mm TT factory rotors and 2 piston calipers- and in this case, the pads were TRW, good fluid, and SS brake lines, so you good say the 2 pots were in bloody condition.
Id expect that if your current 2 piston brake setup is in top condition, you would notice a good improvememnt with the 4 piston upgrade. More sore if you were to.....'track' the celsior?
Hehe, Celsior Lap Sprints, haha!
Ron Bassett
v8 LTD
Reg: 04-2007
Friday, February 05, 2010 - 06:48 pm, by:  Ron Bassett (Ron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I already have the OEM 4 pots, but I am ready to upgrade to better pads and rotors.....so thanks for the part numbers....
Mark Tierney
Soarer GTT, Celsior, Duc
Friday, February 05, 2010 - 07:58 pm, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I grabbed these (QLD manufacturer - Queensland Friction Materials))
- QFM A1RM Pads for the front 4 pots (custom cut)
- QFM Hpx Pads for the rear TT's
http://www.qfm.com.au/images/QFMFlyer.pdf
http://www.gslrallysport.com/shop/index.php?main_page=product_info&products_id=5
Speak to Dave Cazes(from this forum)
Car Torque Products
74 North Tce
Kent Town SA 5067
(08) 8362 7667
No dust, awesome pads.
Good bloke, cheap shipping & very fast service
