Wednesday, March 03, 2010 - 10:08 pm, by: Mat Shiels(Smokeyvip)
damn, i threw mine out last weekend! i'm going to get one made up out of 3mm steel. plan on going llllow. wouldnt cost a lot if you took them the template and it's only one bend really. could even make your own out of sheet, and then get someone with a bender to put the crease in if you're handy with an angle cutter?
you could perhaps entertain that? they are nearly 250 bucks new from toyota/lexus so dont bother askig there.
you can also get pre-fabbed ones off YAJ but they're probably a bit expensive by the time they get here.
Tuesday, March 09, 2010 - 04:56 pm, by: Rich O'neil(Kiwiinaus)
About 2 years ago I left mine off for a while and my engine bay temp went down and I gained about 60 K's extra per tank around town , so I promptly put it back on just to see and sure enough I lost about 50K's per tank , took it off again and the fuel mileage increased , I left it off and it hasn't been on the car since , I have told a couple of other people about this and they had the same results I did so they have left theirs off as well . So maybe you should just not bother with it .
Tuesday, March 09, 2010 - 06:17 pm, by: Matt Shields(Smokeyvip)
my last car was 65mm at the lowest point, i don't expect this one to be much different - and given the sumps hang very low, a 3mm bash plate would be peace of mind.
but i'm running no cover at the moment. interesting about the fuel economy. that would be i guess due to heat soak in and around the intake causing the MAF to adjust the fuel mix to run it richer.
but i'm running no cover at the moment. interesting about the fuel economy. that would be i guess due to heat soak in and around the intake causing the MAF to adjust the fuel mix to run it richer. ??
